Gold Like Dust Particles On Rafters In Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-02-2012, 08:37 PM   #1
Rewards Points: 366
Gold like dust particles on rafters in attic
I was just recently peeking in the attic and noticed some gold like particles on the rafters in the attic. What is this stuff? And is it ok/normal to have in the attic, or an indication of problem? See referenced photo link.
https://www.dropbox.com/s/kmb89ql6m2...fparticles.jpg
daluu is offline   Reply With Quote
Old 07-03-2012, 04:46 AM   #2
Remodeling Contractor
it is just the sap of the lumber leaching out as the wood dries
Old 07-03-2012, 05:34 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
Did someone say....GOLD!?
Old 07-03-2012, 12:10 PM   #4
Rewards Points: 366
Haha, that would be nice. That's what the color seems to be closest to rather than say yellow, orange. Maybe amber is next closest. From where I see it, it is shiny so used gold as the analogous color.
Old 07-03-2012, 12:11 PM   #5
Rewards Points: 366
Thanks, that's good to know.
The Following User Says Thank You to daluu For This Useful Post:
oh'mike (07-03-2012)
Old 06-27-2014, 01:51 AM   #6
Rewards Points: 366
I just came across this article today: http://savenrg.com/venting.htm, but rather than you browse to look it over, the gist of my thread update is this particular info from that article:
If you see these balls of sap boiled out of your rafters, your attic has inadequate venting. This makes your home hot, dries out your structural framing and is an indication your may be spending too much to maintain interior comfort.
this matches with what I saw awhile back, so should I worry about my attic ventilation in the affected area? Might it be underventilated? I live in California and last time I checked, didn't notice any past moisture or mold indicators in the attic, just that sap stuff.
My house doesn't get too hot in summer usually, but can still be pretty hot on the hottest days 90s-100 (with not much wind during then night to cool down). Having home be heat/cool efficient isn't my primary concern (don't have central A/C/heat) but rather longetivity of the attic and roof.
Old 06-27-2014, 05:36 AM   #7
kwikfishron's Avatar
Rewards Points: 772
You never mention how your roof is vented now. Do you have vents at the eves and ridge?
kwikfishron is online now   Reply With Quote
Old 06-27-2014, 11:39 AM   #8
pictures help here.
Old 06-27-2014, 01:38 PM   #9
Doing This Way Too Long
Rewards Points: 532
looks like sap to me
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 06-27-2014, 11:46 PM   #10
Rewards Points: 366
Ok since asked, I've uploaded photos of the roof/attic in question. There's a photo of the single gable vent of the attic, 2 eyebrow/dormer vents on rooftop, one photo of a section of the inside of the attic (rest of attic is like that), and re-showing original photo of the sap on my rafters (original link obsolete). There are no soffit/eave vents, and no ridge vents
It appears at least that my sap isn't as excreted as the one in the mentioned online article. But then again, that was a close up photo, and mine is not as close up. The attic, roof has been like this for at least 10 years.
Gold like dust particles on rafters in attic-attic.jpg   Gold like dust particles on rafters in attic-atticvents.jpg   Gold like dust particles on rafters in attic-gablevent.jpg   Gold like dust particles on rafters in attic-mysap.jpg
Old 06-28-2014, 09:11 AM   #11
Not enough venting to be certain from those small roof top and gable end vents.
How old is the roof?
Either way, you need some more airflow ASAP.
Old 06-28-2014, 10:42 AM   #12
Rewards Points: 366
Roof should be about 12 yrs, it was last reroofed in 2002, and the room addition & attic was built back then.
So what would happen if I leave venting as is? As I mentioned it has been vented this way for ~12yrs.
And if I am to add more venting, where do you suggest adding it? Ridge vent, more dormer vents, or break out some holes in stucco by eaves for soffit/eave vents? There may be some insulation by the walls of the eave. If dormer vents how many more to add?
One roofer proposed 2 o'hagin exhaust vents (replace dormers), adding 3 frameless intake screen vents (appears to be at the eave/wall). The other roofer proposals made no mention of venting changes from current roof.
Old 06-28-2014, 11:55 AM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
I get that sap in lumber that is sitting outside in the shade.
While it's always good to have plenty of ventilation.....I really doubt your attic ventilation is the cause...
Wood does that....some more than others. It's all over my house....besides, you're in San Jose.....never too hot......never too cold.
Nothing to worry about....go have a beer.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
roofermann (06-28-2014), Windows on Wash (06-28-2014)
Old 06-28-2014, 01:43 PM   #14
Gymschu's Avatar
Rewards Points: 930
Lotta sap:
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Collar Tie for attic rafters JoeT Carpentry 15 11-17-2010 07:27 PM
Roof bracing / pulling rafters together JoeT Building & Construction 8 07-08-2010 07:54 PM
Attic Insulation jim_arnau Building & Construction 13 11-07-2007 08:59 AM
Smell and dust in house after cellulose ins. added to attic! Kent Gorsuch HVAC 7 07-17-2007 07:56 AM
