Getting Rid Of A Flat Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-07-2014, 01:32 PM   #1
Getting rid of a flat roof.
Hello, this is my first post and I hope I can be clear on what I am looking for. I have two gable roofs that have peaks going North/South and East/West. They intersect on the North-East corner. In the South-West corner of this intersection the previous owner added on a bathroom and used a flat roof that fits into that 90 degree corner. I am doing some remodeling and have the bathroom gutted and I wanted to modify the roof so it will not be flat anymore. How can I frame the roof so that it will be functional as well as aesthetically pleasing? Below is a link to a very poorly drawn roof of what I am talking about.
i dot imgur dot com/UFmBxTx dot jpg
I hope I was clear on what I have and what I am looking for.
Edit: I can't post links so I hope you can read it.
barn63 is offline   Reply With Quote
Old 03-07-2014, 02:38 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by barn63 View Post
...and I wanted to modify the roof so it will not be flat anymore.
Not hard. A lot of flat roof homes (even nicer MCM's) have had trusses and such put on to make new HVAC and wiring and plumbing possible; not to mention all the insulation value.
That will require someone good and ON SITE to get right.
If you post a few PHOTO's of what's there now...
Try to attach the image. (paperclip icon at top of window)
Old 03-07-2014, 03:48 PM   #3
Thank you for the quick reply. As soon as the snow melts, I will take pictures. I will also attach my picture now.
Old 03-07-2014, 05:08 PM   #4
Metal Roofing
Rewards Points: 600
That is a familiar looking situation, but without a pic it leaves a lot of variables on the table.
I would think your going to be very limited with how much pitch you can add. The more pitch you add the more it will involve the existing roof and wall and the cost with be high. I think the quickest solution (based on no pic) would be a tapered foam system and a new "low" slope roof system.
AndyWRS is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyWRS For This Useful Post:
1985gt (03-10-2014), roofermann (03-08-2014)
Old 03-10-2014, 11:37 AM   #5
Low Slope Roofing
Rewards Points: 114
Most likely framing a new roof slope will be more expensive then putting on a good low slope roof. Tapered insulation and a good membrane will last as long as any shingles if done properly.
1985gt is offline   Reply With Quote
Old 03-14-2014, 12:05 AM   #6
roof
I would put a gable roof on it. That is similar to my home. When I added on to my living room it was in the same spot that your room with the flat room is on. The only thing is, you would have to make sure that the water is running off between the existing hip and the newly built gable. Odds are water won't pool there, but you have to make sure it runs. I like to see it run off fast, but you would have to make sure that it slopes pretty good between the hip and the gable.
I think it would look better with the gable than anything else. Just have to make sure the water runs off to the right. And then a gutter would catch it and bring it to the ground. That is what i would do.
TedLeger is offline   Reply With Quote
extend roof over flat roof nate1582 Roofing/Siding 16 05-21-2012 11:35 AM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
Flat roof related questions christy123 Roofing/Siding 8 12-09-2008 11:30 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
