Gently Sloped Flat Roof Shed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 04:20 PM   #1
gently sloped flat roof shed
Hi all,
Need to re shingle my roof on my shed. Roof is flat and pretty low pitched. From reading here, I re sheath, drip edge the bottom, felt, drip edge sides and shingle. What do I do at the top edge? Just put a drip edge and shingle over it?
B
b_corwin is offline   Reply With Quote
Old 05-14-2010, 04:26 PM   #2
Doing This Way Too Long
Rewards Points: 532
exactly what pitch is "gently sloping" ??
OldNBroken is offline   Reply With Quote
Old 05-14-2010, 04:33 PM   #3
Dunno, not at home to measure at the moment. probably 3/12 or something along those lines. Really small shed, Whole roof probably isnt more than 4'x8'
B
Old 05-14-2010, 05:40 PM   #4
Rewards Points: 532
Try this topic. Rather than re-hashing everyones opinions from that topic this should give you all our opinions in one shot
http://www.contractortalk.com/f15/help-77119/
the way we do it is use a flashing that matches the profile of the drip on the facia plus 1/2" and around 5" on the deck. Shingle all the way to the top, install the flashing then cut the salvage off the last run and install them over the flashing with 1/2" overhang.
You will see the topic above gives dozens of different ways of doing it.
The Following User Says Thank You to OldNBroken For This Useful Post:
seeyou (05-14-2010)
Flat Tar Roof Leak RedBear Roofing/Siding 7 03-08-2010 07:40 AM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
Flat or shed roof Lonicera Building & Construction 2 12-23-2005 03:56 PM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 04:31 PM
