Gas Line Penetration Of Torch Down Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-11-2008, 08:03 PM   #1
gas line penetration of torch down roof
Hi,
I'm having a 3/4" gas line installed in my kitchen. The line will need to come through a torch down roof. Any suggestions on how I would seal this area?
thanks for any help,
Brett
bpiper is offline   Reply With Quote
Old 01-11-2008, 09:53 PM   #2
Before or after the gas is turned on?
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-11-2008, 11:13 PM   #3
Ideally it would happen after the gas was turned on, but maybe I could tend to the roof/pipe junction while the plumber was laying the pipe to the gas meter.
Any way to do this that doesn't involve fire?
Old 01-11-2008, 11:19 PM   #4
Yes, but when you are patching one type of material, you should use the same product for the patching.
I was only concerned about whether or not gas would be in the line, due to the possibility of a leak. BOOM!
Ed
coating torch down roof Betsy G Roofing/Siding 4 10-14-2007 12:40 PM
Torch down roof problem Danimal39 Roofing/Siding 4 04-17-2007 09:06 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
Torch Roof Replacement Question Chad262 Roofing/Siding 6 09-21-2005 08:29 AM
