Garage Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-24-2013, 09:28 AM   #1
Rewards Points: 168
garage siding
yesterday i noticed that there are no nails coming through the sheathing of my newish garage. it is basic cheapo vinyl siding and i am sure 1/2 plywood sheathing. what nails did they likely use ?
Fix'n it is offline   Reply With Quote
Old 08-24-2013, 10:16 AM   #2
Rewards Points: 12,882
Why not pop a piece of the siding loose and see.
There should have been 1-1/4 roofing nails.
If they used 1" instead it's possible they would not come all the way through.
Fix'n it (08-24-2013)
Old 08-24-2013, 11:04 AM   #3
Rewards Points: 2,238
Yeah -
What "Joe" says.
However - if all their nails were hitting "studs" -
You might not see nails through the sheathing.
rossfingal is offline   Reply With Quote
The Following 2 Users Say Thank You to rossfingal For This Useful Post:
Fix'n it (08-25-2013), woodworkbykirk (08-25-2013)
Old 08-24-2013, 11:23 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 852
If done right....they put those nails in on the studs.....and should be galvanized. Large head and they should not be drove all the way in. They are loose so the siding can 'move'.
So....you don't have any drywall on the inside of your garage?
Adding it is one of the best (and cheapest) upgrades for that garage you can do. You will be amazed at how much warmer it will stay.....
Old 08-24-2013, 11:36 AM   #5
If you're going to drywall it -
might as well insulate it.
Warmer.
Old 08-24-2013, 12:28 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 852
And if your going to insulate and drywall it....
might as well run a bunch of outlets..
more outlets for power
The Following User Says Thank You to ddawg16 For This Useful Post:
rossfingal (08-24-2013)
Old 08-25-2013, 09:08 AM   #7
Rewards Points: 168
sheesh, why didn't i think of that
no drywall. and i am not planning any.
Old 08-25-2013, 07:35 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
i always nail into studs when installing vinyl.. the only time that my nails dont go into studs are when the ends of panels dont land over a stud.. in that case the nails are just into sheathing
woodworkbykirk is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
Vinyl siding an old garage? wibass Remodeling 4 03-26-2008 08:27 AM
