Garage Roof Deck Advise - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-22-2013, 11:25 AM   #1
We moved into a place needing some work. There is a garage addition behind the house that was partially completed left for years and the plywood rotted. So I have two options the way I see it.
Option 1: replace what needs replacing, and put that line-x style deck coating down.
Option 2: replace the plywood, and finish install decking to match the deck it is attached to, the usual 2x6 boards and such.
Here is my problem, Option 2, what do I put on top of the plywood for waterproofing before I install the decking? I was looking at the roof underlayment, but they all say not to leave exposed for more than 6 months or so. I could put that coating down but it seems pricey to put it down just to cover it up.
yowmemperor is offline   Reply With Quote
Old 05-22-2013, 04:07 PM   #2
Oso954's Avatar
Rewards Points: 1,110
If you post some pics, you might get more responses.
I would include one from inside the garage showing the roof support.
Oso954 is offline   Reply With Quote
Old 05-22-2013, 04:09 PM   #3
Yeah i jumped the gun, ill get pics tonight. thanks
Old 05-23-2013, 11:55 AM   #4
Low Slope Roofing
Rewards Points: 114
If it's a low sloped roof EPDM or any number of products have been used and lasted a long time.
1985gt is offline   Reply With Quote
Detatched Garage Feed Thru Raised Deck Perry401 Electrical 2 05-09-2013 04:18 PM
Cut into portion of garage pitched roof to make a deck. netsockets Roofing/Siding 1 04-19-2013 01:12 AM
Is it safe to build a roof over my Hawai'i deck? ModelM2HB Building & Construction 11 07-03-2012 06:22 PM
Roof Under Garage Deck doublejz Roofing/Siding 4 04-18-2010 07:09 AM
Restain roof deck without damaging asphalt roof safetycut Roofing/Siding 0 03-09-2010 11:54 PM
