Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 10-12-2011, 04:47 PM   #1
Gap between roof and gutters.
Just the other day me and my girlfriend woke up to some scratching, it sounded like it was coming from the attic. The next day we investigated the roof and saw this.
There is a gap large enough for a squirrel or other small critters to get in and out.
So, how do I got about closing this gap?
I thought about using some metal screening and Great Stuff expanding foam. But I am posting this to make sure that this is the right thing to do.
ben4345 is offline   Reply With Quote
Old 10-12-2011, 05:17 PM   #2
Mod
kwikfishron's Avatar
No foam…it looks like fascia falling down. It looks like it’s up tight down by the downspout and the slope is running the wrong way.
From what I’m seeing you need to pull the gutter, repair the fascia then reinstall the gutter.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 10-12-2011, 05:51 PM   #3
I failed to mention that this runs about 12' then closes to about 1-2cm. Almost like something is "warped". And it doesn't seem to appear on other sides of the house.
Old 10-12-2011, 06:00 PM   #4
Mod
And I bet if you push up under the wood fascia it will close the gap. The only "real fix" is to remove the gutter and repair or replace the fascia (maybe more).
-NEW MEMBERS-
Old 10-12-2011, 06:17 PM   #5
you got the old style gutters too. might as well install new fascia boards and then get new gutters? if you install own fascia boards it will save you a bit of money. just have to measure and cut to size
federer is offline   Reply With Quote
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Gutters with built-up roof? Grebus Roofing/Siding 1 10-23-2010 10:51 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
New roof: GAF v ShingleVent II, warranty, gutters? soubriquet Roofing/Siding 8 08-01-2010 11:17 PM
