Gambrel Roof Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-24-2011, 12:29 AM   #1
gambrel roof leaking
I have a gambrel roof. At the transition slopes (from 4/12 to 20/12 pitch) I have a leak. I just recently had the roof reshingled. The old ripped off and new felt as welll as shingles. They did not put in any flashing on the transition edge and that's where the leak seems to start. How would I go about repairing this? My first thoughts are: to tear off the first row of shingles above the transition edge, then cut the felt and wedge my way up under the felt with tin flashing. And bring the flashing down on top of the first row of shingles after the transition slope. Any help! I am having a problem with this one!
Rfactor is offline   Reply With Quote
Old 04-24-2011, 06:39 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
You've got it figured out, except it seems like the roofers that didn't do it right ought to be the ones doing it.
seeyou is offline   Reply With Quote
Old 04-26-2011, 02:28 AM   #3
Start repair with a thin-bladed pry bar, lifting the sealed edges of undamaged neighboring shingles so can pull out the broken ones. Carefully bend back the good shingles along the top of the damaged area, scratch out the remains of any dead shingles. Pull all visible nails. You should be left with the damaged area now completely free of bad shingles.
myfourseasons is offline   Reply With Quote
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Is my roof going to start leaking soon? smithers76 Roofing/Siding 16 09-04-2010 07:10 PM
Is there anything I could apply to drywall/plaster to determine if roof is leaking? kardplayer2k Roofing/Siding 5 02-07-2010 11:02 PM
Leaking Roof dltigers3 Roofing/Siding 15 01-25-2010 09:25 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
