Gambrel Roof Integrity - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-02-2008, 02:22 AM   #1
Gambrel roof integrity
I need to convert my 1 1/2 story detached garage into a mother-in-law living space - it has a gambrel roof. With a 22' width and no support columns, the 2nd story floor joists are 2" x 8"s and understandably have sagged. I would like to open up the space by removing the floor joists for an exposed-beam look, but don't want to compromise the integrity of the roof (or entire building for that matter). Virtually all the plans I've seen assume that you want a 2nd floor.
Question - do the floor joists provide strength for the roof and overall integrity of the building? Can I remover them completely or would I need to put up scissor rafters or in effect, raise the height of floor joist to just under the second slope of the rafters or other alternate bracing? Don't want it to implode!
Allen Sanders is offline   Reply With Quote
Old 12-02-2008, 07:29 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
On a gambrel roof those floor joists must stay intact, or else the walls will thrust outward and the ridge will start to drop. there isn,t much you can do with a Gabriel other then ruin its integrity.
Old 12-02-2008, 11:49 AM   #3
Many thanks BB. My gut told me the same thing, but I was hoping someone out there had a silver bullet. Thanks for the straight-shootin' BulitBob.
Insulating/Ventilating Gambrel roof billybarty Building & Construction 2 09-25-2009 03:17 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
