Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-04-2010, 06:46 AM   #1
gambrel roof insulation
I'm in the process of renovating a barn with a gambrel roof. We're far from finished but we moved in anyway. We recently noticed major condensation and moisture dripping inside after a quick thaw after a cold spell, and I wondered if I made a mistake in insulating. The moisture went away quickly on its own once the temp dropped again.
It has metal roofing and I used the pink 2" Raft r mate, on the underside before installing the batt insulation. The Raft r mate is advertised as attic venting and this is not an attic, so is it necessary and could this have contributed to this problem? Any other suggestions?
beaks is offline   Reply With Quote
Old 01-04-2010, 09:16 AM   #2
Did you run the Rafter mate the entirety of your rafter cavity?
mark942 is offline   Reply With Quote
Old 01-05-2010, 07:18 AM   #3
Yes, everywhere.
Old 01-06-2010, 06:47 PM   #4
issue and have heard a dozen fixes,none of them very appealing.as soon as the heat makes it through the insulation the roof condensates and it rains on the inside.ive been told to put up a barrier,remove insulation,add twirly birds,stop breathin,add moisture barrier to the ground ect..let me know what you find out,
johnnywalleye is offline   Reply With Quote
Old 01-06-2010, 09:59 PM   #5
Moderator
The baffles allow air from the soffit intake vents to reach the ridge exhaust vent. As per directions, you left 2" between each. http://www.owenscorning.com/around/v...s/VentSure.pdf
1. Then the fiberglass batts, faced- or unfaced?
2. Your location may require a vapor barrier behind the drywall: http://www.buildingscience.com/docum...ecommendations
3. You need an air barrier: http://www.buildingscience.com/docum...wall-approach/
4. or possibly some rigid foam board: http://www.buildingscience.com/docum...on?full_view=1
Be safe, Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 01-07-2010, 07:36 PM   #6
if you would do me the favor look under roofin of last year in late december.look for metal roof condensation i posted pixs of my cabin and how i installed the egg crate and insulation.thank you in advance and so long 4 now john
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Rubber Roof and Roof Deck vianak Roofing 2 10-09-2008 06:37 PM
tin roof insulation 1870Colonial Roofing 5 11-21-2007 07:21 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
