Galvalume Metal Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-29-2010, 07:55 PM   #1
galvalume metal roofing
i am planning to put a metal roof on my house. i like the look of the non painted galvalume. i have checked at several places and they have a 20-25-30 year warranty. is it not all the same if it is galvalume? the 30 yr was several states away. if you know please Help. thanks
turner is offline   Reply With Quote
Old 10-29-2010, 09:03 PM   #2
I am an architectual sheet metal worker and do metal roofs all of the time. Although they are all galvalume they may be different processes or slightly different compounds as manufactures tend to very slightly. Also you want to look at the gauge of the metal. Just like with wiring the lower the number the thicker the metal
jandcwright is offline   Reply With Quote
Old 10-30-2010, 10:29 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
As mentioned above, the warranty difference is likely difference in gauge (thickness) or possibly fastener type. A hidden fastener system is likely to be leak free longer than an exposed fastener system. Make sure you're comparing apples to apples.
Also, some manufacturers are more realistic with their warranties. A 30 yr warranty full of loopholes may be worth less than another manufacturer's 20 yr warranty.
seeyou is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Metal roofing questions Axhammer Roofing/Siding 17 08-10-2010 10:10 AM
Metal Roofing NE dealfiles Roofing/Siding 0 07-05-2010 07:44 PM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 10:49 AM
metal roofing nomoney Roofing/Siding 27 01-12-2009 10:29 PM
