-   -   GAF stormguard for low pitch roofs (http://www.diychatroom.com/f9/gaf-stormguard-low-pitch-roofs-104122/)
Dave K 05-11-2011 12:44 AM
I am putting a roof on our studio apartment that has an area of 2.4/12 pitch and have been advised that an Ice and water shield would be a good idea in that area. I was hoping to use GAF stormguard because from what I understand it is an ice and water shield but when I looked at the box it did not have directions for use on low pitch roofs and said not to use it full coverage unless it is under a metal roof. Looking around on the web I found this
http://www.gaf.com/Roofing/Residenti...218-960-v2.pdf
Reading this I get the idea that the no full coverage issue is due to the lack of being able to pass moisture through the stormguard.
Has anyone used GAF stormguard for low pitch roofs? Our roof ventilation is great and there are almost no obstructions so I assume I am OK on the moisture issue? I live in Northern California and we have ice or snow here so maybe I will be OK with just double felt?
Please help me decide what to do!!!! I have to start putting my shingles on Thursday so it is time to make a decision
Dave K 05-11-2011 12:47 AM
1 Attachment(s)
The lower area of the roof is the only part I would be using the stormgaurd
seeyou 05-11-2011 05:39 AM
That's not full coverage then. Make sure the low slope area is vented well into the steeper area and that it's vented well (which you should be doing anyway) and you'll be fine.
