-   -   GAF Date Code (http://www.diychatroom.com/f9/gaf-date-code-9122/)
hammerhed 06-13-2007 12:23 AM
GAF Date Code
I had a local roofing supply deliver some shingles to my home. The date code on the bundle looked funny. But I was told it was a 2007 made product. When I got into the first pallet, all was well. The two bundles I used so far were limber. These are the GAF Timberline Ultra shingles. The next bundle were stuck together and very stiff. The date code looks like they were made in 2005, instead of 2007 as I think the other two were. There is a whole pallet of them. I can't believe they would sell these as it is apparent that they are not working too well.. Just carrying them up the ladder, over my shoulder caused cracks to form.. I think I might call GAF and ask them what is going one. Any ideas? Anybody familiar with GAF date codes??
Ed the Roofer 06-13-2007 09:44 AM
They don't go about filling anyone in on the information that is embedded into their code sequences, but if the dates are obviously different, the shingles were not manufactured at the same time. Or in other words, came from different "lot" runs.
You should always get shingles for one roof from the same "lot" run, so as to not have a color disparity.
Contact the supplier who sold you the shingles and have them replaced.
Ed
hammerhed 06-13-2007 05:23 PM
GAF Took care of it!!
Ed, you are correct. And I did specify that I wanted matching date codes. Just as I would with siding too.. The warehouse manager told me he would make sure they were of the same lot.. He dropped the ball. BIG TIME!
But,, I contacted the area Rep for GAF and they immediately went to work. They sent a truck over with 19 squares, all of the same date code.
In this case, the color matching is of concern, but the real problem with the shingles, even if they had matched, would most certainly be the condition of a "cooked" shingle that was probably stored incorrectly. ( to the point the adhesive spread out, thus causing the sticky stiff bundle) The logistics of bringing in the Ultras into the inventory as a new product line, on short notice, is the story. Either way, I guess the problem is being resolved. Just have to look at the shingles that I laid down and determine if they are going to stay, or get ripped off.. Only four courses, and the last one has the old junk in it. What would you do Ed? I have Weatherwatch underneath so the holes will not leak. If I let them stay, and they fail, it will be a whole job, or a lot of cement. I am leaning toward removing them and replacing them with the new stock.
Regards
Ed
Ed the Roofer 06-13-2007 05:58 PM
4 rows only so far!
Thats sort of a No-Brainer.
Remove them and replace with all new of the same lot run.
Try to send a bill to the supply house for the "dropping the ball" issue, but be reasonable with the amount and they should cover it. Don't try to strech the $$$ into something outrageous, just for the actual time and materials expended.
Have them throw in one roll of Ice and Water Shield as a comp for the hassle and either go over the sheet with the holes in it after you do the tear-off or extend an additional row on the side of your home that gets the most severe ice-damming problems on a recurring basis.
Ed
