Gaco Roofing Sealers: Any Good? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-04-2007, 05:40 PM   #1
Rewards Points: 24
Question
Looking to seal my flat hot mop roof that I believe is a torch down (or rubber??) that has a white sealer over it that is mostly pealed off due to age. Roof is leaking in spots but no obvious cracks or anything in black smooth material (torch down?) under white sealer that is mostly pealed off. The roof is very smooth but it's unclear to me if it's rubber or torch down (how could I tell the difference??).
I found at my local hardware store a roofing sealer by Gaco (see http://www.gacoretail.com/gacoroof.html) that has a lifetime limited warranty and claims it even holds up under pooling water.
Does anyone have experience with this product?
Just found another product named Liquid EPDM Rubber, anyone have experience with this? http://www.epdmcoatings.com/?OVRAW=e...ID=31213446522
WynsWrld98 is offline   Reply With Quote
Old 08-04-2007, 07:00 PM   #2
Commercial Roofing
AaronB's Avatar
I keep hearing "too good to be true"
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 08-04-2007, 07:04 PM   #3
Rewards Points: 24
too good to be true about the Gaco product and/or the Liquid EPDM product?
Old 08-05-2007, 09:31 AM   #4
Read through the exclusions to the warranty and see what the limitations of the limited warranty actually cover.
Typically, it will offer additional product for any product failure, but no compensation for additional labor or damage to the structure or contents contained within the structure.
It really does not cover that mush after all.
Liquid Rubber is just a brand name for an elastomeric coating.
Ed
Ed the Roofer is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 09:23 PM
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 05:31 PM
