Gable Vents Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 10:25 AM   #1
Rewards Points: 77
Hello All,
Going to replace my 25 year old Gable vents this weekend. Going to go with the Masterflow 1600cfm PG3 here: http://www.homedepot.com/p/Master-Fl...6#BVRRWidgetID
Same size dimensions as the old Broan ones there now. I still have the paperwork from the Broan ones from 25 years ago if you can believe it.
Anyone make a good recommendation to minimize vibration down the walls? Maybe I need to make a change to the way I mount it or put something in between the brackets and the plywood there now? Rubber, plastic or a 3/4" piece of strapping? Or maybe the ones there now are just so old that a bearing is out of whack causing the vibration??
Any thoughts recommendations welcomed.
Thank You,
~S
Skelleyman is offline   Reply With Quote
Old 04-18-2013, 10:55 AM   #2
Rewards Points: 13,300
Why not just install a ridge cap on the roof and get rid of any vibration, no power used, vents the whole roof not just one end of it.
need some help with ridge vent + soffit vents allthumbsdiy Roofing/Siding 14 10-19-2012 04:44 PM
new cool vent roof; close gable vents? MNhome Roofing/Siding 17 08-22-2012 10:32 AM
Should gable vents be sealed after DCI smartvent is intstalled? mesaAZ Roofing/Siding 2 04-02-2011 12:00 PM
Gable fan? Powered roof vent? idahojoec Roofing/Siding 2 07-25-2009 03:06 PM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 10:17 AM
