-   -   Gable Vents Replacement (http://www.diychatroom.com/f9/gable-vents-replacement-177456/)
Skelleyman 04-18-2013 09:25 AM
Hello All,
Going to replace my 25 year old Gable vents this weekend. Going to go with the Masterflow 1600cfm PG3 here: http://www.homedepot.com/p/Master-Fl...6#BVRRWidgetID
Same size dimensions as the old Broan ones there now. I still have the paperwork from the Broan ones from 25 years ago if you can believe it.
Anyone make a good recommendation to minimize vibration down the walls? Maybe I need to make a change to the way I mount it or put something in between the brackets and the plywood there now? Rubber, plastic or a 3/4" piece of strapping? Or maybe the ones there now are just so old that a bearing is out of whack causing the vibration??
Any thoughts recommendations welcomed.
Thank You,
~S
joecaption 04-18-2013 09:55 AM
Why not just install a ridge cap on the roof and get rid of any vibration, no power used, vents the whole roof not just one end of it.
