Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-18-2011, 08:54 PM   #1
Post
Are gable vents adequate for intake ventilation?
Am a DIYer in most things but this is outside my know-how. I have 10 year old roof with curling/bare (25 yr) Certainteed shingles in Wisconsin. Will be filing claim w/manufacturer. Contractors giving me estimates say inadequate attic insulation & ventilation contributed to deterioration. The contractor I'm leaning toward proposes replacing box exhaust vents with ridge vent and leaving gable vents (east/west) in place for intake. Building does not have soffets. From what I read, gable vents are not very effective, is there a cost efficient alternative? Attic is approx 1300 sq feet, is fairly shallow, preferred contractor says they would pack insulation up higher than gable vent & install baffles to allow for airflow & would replace 12x12 gable vents (at my request with 12x24 or 12x36). Any red flags here?
Is Ed the Roofer still out there? Have been finding some of your advice to others helpful.
Bryan5665 is offline   Reply With Quote
Old 10-18-2011, 10:59 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
I am not understanding what you are calling gable vents.
Gable vents are usually located on the gable end up fairly high on the gable to allow air from the lower eave vents to exhaust through.
Could you explain a bit further?
Andy.
AndyGump is offline   Reply With Quote
Old 10-19-2011, 08:20 AM   #3
Exterior Construction
Windows on Wash's Avatar
Gable vents have worked for years and years and while they do not provide an ideal ventilation (ideal is a continuous undercurrent of air from the soffits to the ridge-line) they can still be sufficient.
There are products that allow for eave ventilation without soffits and most situations I see you can get some intake air from near the eave.
Ventilation is just to control moisture. Get the attic air sealed and insulated and your shingles will be fine. FYI, anyone claiming that ventilation killed your shingles is wrong.
The Following User Says Thank You to Windows on Wash For This Useful Post:
AndyGump (10-20-2011)
Old 10-20-2011, 08:02 PM   #4
Andy.
Hi Andy- the roofer is proposing that the gable vents located just under the ridge on front/back sides of building will be adequate for intake ventilation, they would install ridge vent for exhaust. It's a 1926 building with no eaves. Attic depth is only about 3-4ft. They would blow in insulation up to just under the gable vents. Will this configuration provide enough ventilation?
Thx, Bryan
Old 10-20-2011, 08:13 PM   #5
ParagonEx's Avatar
Where in WI?
I would check into the DCI products.
ParagonEx is offline   Reply With Quote
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing 1 09-07-2011 11:13 AM
Should gable vents be sealed after DCI smartvent is intstalled? mesaAZ Roofing 2 04-02-2011 12:00 PM
Do I need the gable vents bjakeski Roofing 4 08-17-2010 06:17 PM
No soffit or gable vents wooody Roofing 8 08-19-2009 09:06 AM
Big trouble with gable vents! Beth777 Building & Construction 9 08-11-2008 08:32 AM
