Gable Vent Spot - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 03:09 PM   #1
Gable Vent Spot
I am looking to install a gable vent with a fan in my attic. Problem is where I am going to place the vent there seems to be a beam or something in the way. My question is this: If I cut this will it compromise structure? Yellow arrow marks piece in question.
pjm30043 is offline   Reply With Quote
Old 07-31-2012, 03:16 PM   #2
Rewards Points: 13,296
Why a gable vent and not a ridge vent?
A ridge vent will vent the whole roof not just the ends of the attic.
Old 07-31-2012, 03:20 PM   #3
Because I do not have any eves on the back of the house to put soffits vents in. This seemed like the next best solution.
Old 08-03-2012, 01:24 AM   #4
Registered User
Rewards Points: 5,216
Why are there no vertical studs on that (stressed) gable truss? No, do not cut it unless there are solid headers over the doors/windows in the walls below.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
seeyou (08-03-2012)
Old 08-03-2012, 07:57 AM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Don't cut it anyway. That's a standard truss - not a gable truss.
seeyou is offline   Reply With Quote
Old 08-03-2012, 07:59 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
You still need inlet with a gable vent, especially if you're putting in a power vent. If you don't provide proper inlet, the fan can pull from inside the living space. More info is required.
Old 08-03-2012, 08:25 AM   #7
A picture of the outside of the home may help come up with some ideas.
seeyou (08-03-2012)
How to properly seal a gable vent? Lynch Roofing/Siding 3 08-05-2011 05:39 PM
Old Work Gable Vent obricko Roofing/Siding 0 05-21-2011 11:53 AM
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 04:06 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
