-   -   Gable Vent Spot (http://www.diychatroom.com/f9/gable-vent-spot-152142/)
pjm30043 07-31-2012 02:09 PM
Gable Vent Spot
1 Attachment(s)
I am looking to install a gable vent with a fan in my attic. Problem is where I am going to place the vent there seems to be a beam or something in the way. My question is this: If I cut this will it compromise structure? Yellow arrow marks piece in question.
joecaption 07-31-2012 02:16 PM
Why a gable vent and not a ridge vent?
A ridge vent will vent the whole roof not just the ends of the attic.
pjm30043 07-31-2012 02:20 PM
Because I do not have any eves on the back of the house to put soffits vents in. This seemed like the next best solution.
Gary in WA 08-03-2012 12:24 AM
Why are there no vertical studs on that (stressed) gable truss? No, do not cut it unless there are solid headers over the doors/windows in the walls below.
Gary
seeyou 08-03-2012 06:57 AM
Don't cut it anyway. That's a standard truss - not a gable truss.
seeyou 08-03-2012 06:59 AM
You still need inlet with a gable vent, especially if you're putting in a power vent. If you don't provide proper inlet, the fan can pull from inside the living space. More info is required.
joecaption 08-03-2012 07:25 AM
A picture of the outside of the home may help come up with some ideas.
