Gable Vent With Roof Vent. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-19-2012, 02:11 PM   #1
Gable vent with roof vent.
My house is a ranch style that doesn't have eaves in the back. The front does and the addition that was added before I owned the property does. Some roof vents were installed before I bought the house but not nearly enough as suggested by the vent manufacturer per sq foot. My question is should I add gable vents in addition to the roof vents(which I will be adding 4 more)?
pjm30043 is offline   Reply With Quote
Old 06-19-2012, 04:56 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Exhaust always needs to be balanced with intake.
Old 06-19-2012, 06:20 PM   #3
So seeing as though I don't have nearly enough soffit vents it would be ok to install gable vents?
Old 06-19-2012, 06:47 PM   #4
Rewards Points: 880
On most home, exhaust is not in nearly as a short supply as intake.
Most homes are lacking intake volume.
Old 06-19-2012, 08:17 PM   #5
Pro
JetSwet's Avatar
Rewards Points: 502
You should have enough soffit vents but I would make shore there not fake soffit vents.
You should either have gable vents or ridge vents but you should not have a attic fan as well with the exhaust vents because you dont want to speed up the ventilation in your attic.
JetSwet is offline   Reply With Quote
Old 06-19-2012, 11:04 PM   #6
Should I close off the roof vents and just add gable vents with a gable vent fan?
Old 06-20-2012, 08:14 AM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
You need a intake and exhaust. If you have no intake then the fan will full from inside your home you don't want that. Do you have a ridge vent?
Do you have prior gable vents? If so are they on the peek of roof or bottom of roof and where are the fins slanted up or Down.
With a bottom gable vent and a ridge vent you will be fine.
Old 06-20-2012, 08:40 AM   #8
Rewards Points: 83
It depends on what you want to add, more intake or more exhaust.
If you want more intake then add more soffit vents, if you want more exhaust, then add more roof vents or a gable vent.
bcdemon is offline   Reply With Quote
Old 06-20-2012, 08:51 AM   #9
Rewards Points: 850
im in airzona with summer temps in the 110 plus range. most of the homes here dont have much for sofit vents but a lot for roof vents. the part of the country you live has a lot to do with it.
hotrod351 is offline   Reply With Quote
Old 06-20-2012, 04:41 PM   #10
I actually live in the souhteast which has notorious hot and humid summers. I actually want both more intake and exhaust and the only place there are soffit vents is in the front of the house with no where to put them in the back.
Ridge Vent with roof vents and Soffit vents apquery Roofing/Siding 10 08-08-2016 10:28 AM
Can I use one roof vent for 2 bathroom exhausts fans? P550 General DIY Discussions 19 05-18-2014 10:41 PM
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 12:57 PM
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 04:06 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
