Gable Roof Leak Between Plywood -PICS - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 11:32 PM   #16
Registered User
Rewards Points: 5,514
Measure the plywood thickness when replacing it. 3/8" (24/0) is the only one (unless you have a heavy snow load) requiring H-clips in plywood grades if 24"o.c. 7/16", 15/32", 1/2", 19/32", 5/8" do not. I'm guessing 1/2", very popular (and a lot cheaper) for 24"o.c. at that time, check for it. Building inspectors usually check for that... Just read the ink stamp: http://www.apawood.org/pablog/index....f-plywood#more
http://www.apawood.org/pablog/index....Roof-Sheathing
Gary
Old 09-13-2012, 06:11 PM   #17
So, this is how it turned out (: and again, thanks for everyone's input and direction!
Tryskylife is offline   Reply With Quote
Open Gable Porch Roof Lakeowner Roofing/Siding 3 11-06-2011 09:40 PM
Question about vents on roof and roof leak. fenster4 Roofing/Siding 1 10-28-2010 01:49 PM
Why Does my Flat Roof Leak? KATHIE Roofing/Siding 15 02-19-2009 11:57 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
