Frost Covering The Inside Of My Roof This Winter? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-19-2014, 05:39 PM   #1
Frost covering the inside of my roof this winter?
The inside of the attic was covered in a thick layer of frost this winter, when it melted it leaked and got the roof wet. Why would this happen, i have been living here for five years and it hasn't happened before. I recently last summer got new shingles put on my roof. What would cause this and how do i fix it?
kenny111 is offline   Reply With Quote
Old 03-19-2014, 05:46 PM   #2
Rewards Points: 1,292
The cause is the attic dew point temperature being too high. One solution to fix is to stop exhausting bath fan air into the attic.
Old 03-19-2014, 05:48 PM   #3
i checked the connection of the exhaust fan from the bath room. It is connected and vents direct to outside with no leaks.
Old 03-19-2014, 06:03 PM   #4
Rewards Points: 13,748
Most often caused from not enough roof and soffit venting, attic not air sealed, and not enough insulation.
No one has a clue where you live because there's no location in your profile.
Going to quick links to edit would be a big help.
http://www.energystar.gov/index.cfm?...sulation_table
Air sealing is sealing up anyplace wiring, plumbing, ceiling fixtures where run into the attic.
Old 03-19-2014, 06:06 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Need more venting and balanced venting.
Air sealing is going to help with the moisture transfer.
Old 03-19-2014, 06:16 PM   #6
What do you have now for roof and soffit venting?
Old 03-19-2014, 06:26 PM   #7
Asphalt and individual soffits under the eaves.
Old 03-19-2014, 06:50 PM   #8
That does not tell us much.
What types roof vents, gable, ridge vents?
Just a few soffit vents is not going to cut it.
If they have been painted over, cover with insulation there useless.
Picture sucking on a straw with your finger over the end of it.
Old 03-20-2014, 12:50 AM   #9
Registered User
Rewards Points: 5,516
http://www.buildingscience.com/docum...bout-diffusion
http://www.energysaversny.com/frost_-_moisture
Gary
PS. Welcome to the forums!
Tags
attic , condensation , frost , insulation , roof
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
