Framing A Hip Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-21-2010, 01:16 AM   #1
Rewards Points: 180
framing a hip roof
I understand how a simple hip roof is framed, basically it cuts in every corner and forms a triangle. Now I'd like to know how to do the same thing when you have a wall that is not straight.
Let's say you have a wall that is 20' and 5' of those 20' was in by 2'.
If the wall were straight, you'd have a triangle 20' at the bottom. But what if you wanted the 15' part to look like it was cut and moved 2' out (holding the same pitch, just bumped out 2')
As in the picture here: Where does the '1' stub ridge attach and what supports it?
If you just tag onto the other hip behind it, it wouldn't have very much strength would it?
Note there is no wall under this, the walls are only where the outer edges are.
KarlJay is offline   Reply With Quote
Old 10-21-2010, 05:33 PM   #2
Rewards Points: 180
I think I might have found the answer. I'd be doing a mod of what is pictured here:
Instead of coming out to plumb, I'd be coming out to the same pitch as the other section. Is this the correct way to do this?
Old 10-24-2010, 12:58 AM   #3
Framing Contractor
In a case like that you run that ridge into the main roof common rafter. You don't need the big hip for the main roof on the bottom right side in your drawing. All you need is a smaller hip called a, "Broken Hip".
Joe Carola
Joe Carola is offline   Reply With Quote
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 11:24 AM
gable roof tie in framing moonshadow Roofing/Siding 4 08-20-2009 08:03 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Need help with framing roof for sunroom diehard_1955 Carpentry 1 04-27-2005 10:24 PM
