-   -   Foil Backed OSB (http://www.diychatroom.com/f9/foil-backed-osb-7966/)
DaveHembree 04-23-2007 01:17 PM
Foil Backed OSB
Just wondering from the group the opinion on using foil backed OSB for roofing. I realize the ongoing debate on OSB vs. Plywood, but that aside - is it worth the extra cost to use Foil backed OSB vs. regular OSB? I have heard that the foil backed OSB will reduce the heat in the attic and thus *should* help lower the utility usage in the house.
Just wondering if anyone has any real world experience with this?
RooferJim 04-23-2007 06:00 PM
I have learned from years of experience that all OSB is unsuitable for a subroof. Get CDX plywood .
RooferJim
www.jbennetteroofing.com
AtlanticWBConst. 04-23-2007 06:05 PM
OSB out....CDX -in
Ed the Roofer 04-23-2007 07:19 PM
The foil faced "PLYWOOD" is available if you choose to utilize this concept. Chech out the following link regarding Plytanium from GP.
http://64.233.167.104/search?q=cache...lnk&cd=7&gl=us
AtlanticWBConst. 04-23-2007 07:56 PM
Ed, What do you think of that product?
Ed the Roofer 04-23-2007 09:31 PM
I have no personal experience with it, nor do I personally know anyone who has made their position clear on the product whom I trust.
The reports I have read in the past and now seem to indicate it maintains a cooler interior temperature.
As with any new product, the jury is still out.
Ed
AtlanticWBConst. 04-24-2007 05:16 AM
Originally Posted by Ed the Roofer (Post 42071)
.... As with any new product, the jury is still out.
Ed
...So very true ....
AaronB 04-26-2007 01:13 AM
OK, here are my thoughts on foil backed products marketed as radiant barriers....
Its B.S. Foil facing can only reflect heat before it becomes heat. It can only reflect light. After the sun's light has made contact with your roof, the light energy is changed to heat energy. The foil can certainly absorb and radiate heat, but it cannot reflect that heat unless it is on the very outside, exposed to the UV light.
AtlanticWBConst. 04-26-2007 06:38 AM
Not trying to start anything.....
Do you have links to information or studies regarding the points you are stating? As I wrote, I have never used the product.....
AaronB 04-26-2007 09:05 AM
I do not....it was learned in 6th grade science class. Metals absorb and conduct heat. No mfg rep has ever been able to explain it otherwise.
parkerfairfield 04-28-2007 02:51 AM
Hmmm.
Well, since we're all opining.... I sold a lot of LUMINOX.
The reason why ... is because of the 'science' they quoted. And yes, this quote could be purchased crap... a la the Institute that certified cigarettes made you cool and they have nothing to do with cancer.
The link to their PDF is here.
the Spiffy quote is here: Found in bottom right of page 2
Geoscience LTD, an independent testing facility, has documented through the use of ASTM C-236 test methodology the following: • Roof temperatures of up to 123° yield 21-22% air conditioning energy savings. • Roof temperatures in excess of 123° yield savings between 25-30%. In other words, the hotter your roof deck gets, the more you save on your air conditioning bill. • For a copy of the report contact Ainsworth at 1-877-661-3200.
portland 05-03-2007 05:29 PM
Study says foil-sheathed OSB may not help much–might hurt.
http://www.ornl.gov/sci/roofs+walls/radiant/index.html
http://www.ornl.gov/sci/roofs+walls/radiant/rb_02.html
Suggests that at best, the use of various types of radiant barriers might reduce cooling needs by 2 to 10 percent, in summer, in a warm climate. HOWEVER, a radiant barrier may also reduce beneficial heating in winter. Also, the more standard insulation you have in your attic (R-19 should be a minimum), the less difference a radiant barrier would make.
Short story: in summer, it may not be worth the added cost; in winter, the jury is still out whether it helps at all–or maybe even hurts. Attic insulation (batts or blown-in) is a sure thing in all climates and seasons.
Save your money?
Ed the Roofer 05-03-2007 08:59 PM
A little more information about radiant barrier decking.
from buildingscience.com
Ed
Effect on Shingle Life
In general, shingles installed on unvented attic assemblies operate at a slightly higher temperature. This has impacts on the durability of roof assemblies. A 2 or 3 degree F. rise in average temperature is typical for asphalt shingles and a corresponding 10 degree F. rise in average temperature for sheathing (Parker & Sherwin, 1998; Rudd & Lstiburek, 1998; TenWode & Rose, 1999)
All other things being equal, applying the Arrhenius equation (Cash et.al, 2005), a 10 percent reduction in useful service life should be expected. This is comparable to the effect of the installation of radiant barriers. What is more significant to note is that the color of shingles and roof orientation have a more profound effect on the durability of shingles than the choice of venting or not venting (Rose, 1991) – double or triple the effect of venting/non venting.
parkerfairfield 05-04-2007 02:36 AM
Save your money?
To start out ... I hail from New England... my mom lives in 'the Birth place of Vermont' - Windsor.
I (semi-unfortunately; it's complicated like most things in life) live in California.
Like many of the 'cool roofs' YMMV (your mileage may vary).
Funny anecdote ... we were putting a PVC roof on in April 2005... in Gilroy, CA - the 'Garlic Capitol' of the world. Anyway, at 7:30am there was 1/8 inch of ice across the WHOLE roof. Go to Google... you'll see that for a standard BUR, it shouldnt be cold enough. POINT = it is a COOL ROOF all the time... which is why you'll see ALL of the marketing material re: 'Cool Roofs' talking about the "COOLING SAVINGS" - not the ENERGY SAVINGS (as was pointed out, the winters will result in an INCREASE in heating costs unless the roofer salespeople (a) are educated to this fact (b) are good enough educators to TEACH this ROI concept to the homeowner.
Finally, if you're in COLD areas... you've PROBABLY enough insulation to deal with the fact that you're not going to be heating up the attic the additional few degrees. It's my GUESS that if it is tit freezing cold outside, an additional 2, 5 or 10 degrees F drop in attic temp is not going to have a big hit on your heating bill.
Just my R-4.
parkerfairfield 05-04-2007 02:44 AM
Ed
Ed, this is a FANTASTIC point.
Let's pretend Bill Gates dies and leaves all of his money to you. You decide to buy Certainteed or OC.
Would you then radically alter the warrantees on all of the BLACK shingles that are currently offered with the same warrantees of the more 'yellow' or 'gray' versions?
NAH.
You'd rely on the fine print... like everyone else - at least, the average LAWYER would.
Non-vented... well in this market, that voids the mfg warranty.
And Elk, GAF, and C'teed are still mute on the usage of foil-backed ... and 'allow' it when pressed.
Therefore, they are acting like LIFE INSURANCE agents - relying upon the law of averages:
.... the avg house will be sold 2x before 'premature' failure...negating the warranty
.... if not sold 2x, the avg homeowner won't have the paperwork... negating the warranty CLAIM
.... someone with the paperwork , when learning of the pitiful little amount will be given them in the year 2026 will just decide it's not worth fighting for it
Meaning they'll pay out 1% of the POTENTIAL claims.
Overly Cynical?
