Foam Roofing/skylights - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-18-2012, 07:02 PM   #1
foam roofing/skylights
how do I install a skylight on a foam roof
Dave4b is offline   Reply With Quote
Old 08-18-2012, 07:05 PM   #2
Rewards Points: 14,294
Now I know that's never going to be enough info.
What's the pitch?
Do you really mean a SIP roof?
Want ansewers going to have to tell us in detail how the the roof was built.
Pictures are also great.
Old 08-18-2012, 07:07 PM   #3
its on a flat roof
Old 08-18-2012, 07:17 PM   #4
Still going to need to know what's covering up the foam.
Hot mop, PVC, EPDM ECT.
It not going to be a DIY job in any case. If it was mine I would only let a company that does commercial roofing do it. But ha that's just me.
Commercial roofers do far more flat roofs. And with any flat roof it's not if it's going to leak but when.
tinner666 (08-18-2012)
Vapor sealing with open cell foam insulation PerpetuallyRepairing Insulation 6 12-17-2011 09:16 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Replace Flange in basement with Foam? mattoxda Plumbing 1 10-10-2010 04:05 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
