Foam Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-18-2010, 04:54 PM   #1
Rewards Points: 154
Foam Insulation
I just had my contractor open my sofit vents for continous air flow, and now plan on getting a new furnace, the furnace man suggest i get more insulation in the attic so he recommended a guy. This company comes over today and tells me the best way to insulate an attic is to use this spray foam, in addition he tells me the ridge and intake vents needs to be closed off. IN essence he is telling me the attic with this foam stuff, is air tight no air coming in or out. (to me based on what I've heard hear and other sources, this sounds crazy.) then he says all new high end homes are doing this, this is coming from a company who makes their living off of installing insulation, what do you make of this?
turbomangt is offline   Reply With Quote
Old 10-18-2010, 06:06 PM   #2
jlhaslip's Avatar
Rewards Points: 2,186
He is a salesman selling his product.
Of course you need what he is selling... NOT!
Ask your contractor about adding more loose fill or batt insulation. It will be equally beneficial and lots cheaper.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-19-2010, 09:41 AM   #3
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
You will almost assuredly void your shingle warranty. Check with the manufacturer of your shingle roof before choosing to have the attic insulated with spray foam, most shingle manufacturers have warranty exclusions for spray foam reducing the warranty in half.
The practice is becoming more and more common, but I am very interested in seeing how the shingle roofs hold up in the next 5-10 years. However in my experience even the high end homes here still have batt or blow in fiberglass attic insulation.
Many many churches will have an insulated roof deck, which is similiar to spray foam on the bottom side of the sheathing. These roofs seldom last longer than 20 years because the added expense of installing a ventilated nail base can nearly double the cost of a job and most people don't understand how essential ventilation is to the life of a shingle. Furthermore I have heard rumor of the off-gas from the spray foam actually also causing harm to the shingle further accelerating the break down.
Truth be told in my opinion we do not yet have conclusive evidence one way or another in regards to spray foam on the bottom side of a roof deck, w/o ventilation. I'm sure there are accelerated weathering tests done out there, but I don't often beleive in those type tests. Time will tell.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 10-19-2010, 10:16 PM   #4
RoofDiagnostics's Avatar
Maybe the furnace would benefit from removing all of the roof ventilation? ~this i am not sure~
Your roof would suffer from removing the ventilation. Do not eliminate the roof ventilation.
RoofDiagnostics is offline   Reply With Quote
Old 10-19-2010, 11:19 PM   #5
Rewards Points: 956
yea thats the exact same they are proposing to do with my attic. spray foam seal it shut
federer is offline   Reply With Quote
Old 10-20-2010, 12:46 AM   #6
Inquiring Mind
Stupid question here Grumpy, but does that apply to aluminum shingles? Personally I wouldn't think so but this isn't my dept.
sassyalice is offline   Reply With Quote
Old 10-20-2010, 10:55 AM   #7
Grumpy's Avatar
Rewards Points: 540
I wouldn't think so with metal shingles but you'd have to contact your local building department and the manufacturer of the metal shingles.
The Following User Says Thank You to Grumpy For This Useful Post:
sassyalice (10-20-2010)
Old 10-20-2010, 01:14 PM   #8
Rewards Points: 154
They are really advertising this foam stuff, saw it in the paper....I just can't see sealing off ALL ventilation and air flow in the attic, after all the crap I went through to get my roofer to come make (9 momths later) to open up my sofits again, and make continuous intake vents, I just can't see closing it all off, sealing the ridge vent, and spending 4 times what fiberglass insulation would cost, someone is getting rich off this, thank goodness for places like this to educate us consumers, G
Old 10-20-2010, 09:51 PM   #9
Tom Struble's Avatar
Rewards Points: 2,002
it all has to do with the dew point and where its located
Tom Struble is offline   Reply With Quote
Old 10-20-2010, 09:52 PM   #10
Registered User
Rewards Points: 5,516
The new 2009 IRC has the requirements listed here: http://publicecodes.citation.com/ico...006_par003.htm
And Building Science is right there too: http://www.buildingscience.com/docum...archterm=attic+
It’s been known for a long time venting is mainly for condensation in the attic, not cooling the shingles: http://www.fpl.fs.fed.us/documnts/pdf2002/rose02a.pdf
Another: http://www.buildingscience.com/docum...r-all-climates
Gary
Old 10-20-2010, 10:48 PM   #11
Rewards Points: 956
so spray foam doesnt hurt the shingles at all
Old 11-02-2010, 11:09 AM   #12
Grumpy's Avatar
Rewards Points: 540
Originally Posted by GBR in WA View Post
Itís been known for a long time venting is mainly for condensation in the attic, not cooling the shingles: http://www.fpl.fs.fed.us/documnts/pdf2002/rose02a.pdf
Gary
I really could not disagree more.
Scuba_Dave (11-02-2010)
Old 11-02-2010, 12:30 PM   #13
Registered User
“Adequate attic ventilation is a long-standing requirement in building codes for moisture control. However, conditioned, unvented attics can reduce residential energy needs and are allowed by the code under certain conditions. Such assemblies are sometimes called cathedralized attics because, as with cathedral ceilings, the insulation is in the rafters and/or roof deck. The primary benefit of cathedralized attics is the ability to locate HVAC ducts inside conditioned space, where duct leaks and heat losses/gains are not detrimental to the home''s energy bill.” From 2006 IRC: http://docs.google.com/viewer?a=v&q=...kV-ztF0DKEvW7w
March 2002, from your peer’s magazine:
Conclusions
The following conclusions are based on data from our numerical model:
  • The greatest influence on roof temperature is geographic location. The mean roof temperatures for Miami and Green Bay, Wis., for example, differ by 18 degrees Celsius.
  • The direction a roof faces has the second greatest influence on average roof temperature (in excess of 1.44 degrees Celsius in the east through south-to-west range studied, but the real difference is greater because other directions, such as north, will be cooler).
  • The color of roofing materials influences the mean temperature of a roof system slightly less than direction (1.45 degrees Celsius average for these parameters).
  • Ventilating the area under a roof deck reduces the average temperature 0.5 degrees Celsius (about one-third the influence of the direction or color and one-thirty-sixth the influence of geographic location). Even with wind assistance, ventilation reduces average roof temperature about half as much as using white rather than black shingles.
  • Within the ranges studied, slope has the least influence on average shingle temperature.
http://www.professionalroofing.net/a...2/feature2.asp
I really could not disagree more.”------- Which particular point?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
federer (11-02-2010)
Old 11-02-2010, 09:44 PM   #14
Rewards Points: 956
wow good rebuttal....i sit waiting :P
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Is spray foam insulation that much better than fiberglass? HautingLu General DIY Discussions 18 09-21-2010 06:36 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
