Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 03-05-2012, 09:28 AM   #1
Foam board over old 4in thick fiber board roofing panels
Our neighbor lost his roof in a tornado last week and we are trying to come up with a new roof system with additional insulation properties. This is an older home with 2ft x 8ft x 4in tongue and groove fiber board roofing panels nailed directly to the interior exposed beams. These are structural panels and the beam widths are 4ft. Roof pitch is approximately 4-12. After the storm, all that is left is the roofing panels and the roof is currently tarped for protection. We are contemplating adding some type of foam board, then OSB (or Advantek), then felt and shingles. The foam board is to increase the R-value of the roof. Our concerns are 1) fastening anything to the old fiber board since conventional fasteners tend to pull out, 2) trapping moisture that could eventually reach the fiber board. Your thoughts are appreciated.
Rebob40 is offline   Reply With Quote
Old 03-05-2012, 09:45 AM   #2
Tom Struble's Avatar
insulation and venting in 1 panel,contact them for info on special fastening requirements
http://www.hpanels.com/images/storie.../Cool-Vent.pdf
Tom Struble is offline   Reply With Quote
Old 03-05-2012, 10:24 AM   #3
Exterior Construction
Windows on Wash's Avatar
Air Seal the T&G boards by applying ice and water or other sealing membrane.
Add rigid foam to exterior to suitable depth for climate region (where are you located).
Install 2x4 sleepers and plywood deck over top.
Install proper coverings for over deck vent space created.
Install new roof system.
Ridged foam board in attic, going for R-40 sentz Insulation 6 03-04-2012 01:27 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 05:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing/Siding 3 07-25-2005 06:31 PM
