Flintlastic SA Over Existing Torch Down Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-15-2012, 11:12 PM   #1
Rewards Points: 72
Flintlastic SA over existing torch down roof?
After posting questions regarding what to do with a shed roof, Proper transition between shed roof and shingled roof? , I have decided to use Fintlastic self adhesive. Poking around the Certainteed web pages I have found reference to applying it over an existing roof - but I am unable to find any technical documents about doing so. THe shed roof appears to have a torch applied roof coating. The shed roof surface does not show any degradation (but it does have wrinkles in the surface - and I realize the new surface will have the same wrinkles reading thru (see picture links in the original message)). Twice I have applied an aluminized asphalt based roof coating to minimize future weathering. I don't have an issue with the shed roof but I see not reason to lap over it with the shingles only to have to lift the shingles up in a few years when the shed roof needs replacement.
So any advice on applying the Flintlastic over an existing roof? Will I have adhesion issues w/ the brush on coating that I applied?
aribert is offline   Reply With Quote
Old 05-16-2012, 05:42 AM   #2
gwa
The Flintlastic should be under the shingles, not over them. Based on the appearance of your shingles, they look like old organic shingles that will require replacement in the next year or so. Your existing modified bitumen roof on the shed looks much better than the shingles. I would replace the shingles.
The Flintlastic SA modified bitumen must be installed at least 24" up the slope under the shingles to prevent water and snow melt from getting under them.
A concrete primer should be fine over the existing roof before installing the new Flintlastic modified bitumen. Although it is called concrete primer, it is used to prime anything that a bituminous roof is installed to. Any commercial roofing supply house should stock it.
gwa is offline   Reply With Quote
Old 05-16-2012, 07:32 AM   #3
Rewards Points: 72
gwa
Thanks for the reply. I guess that I was not clear in my posting, the need to replace the shingles is what is promping me to redo the shed roof so that the shed roof surface will shingle under the new 3-tab shingles.
Thank you for the info on the concrete primer! This is the kind of info that I was hoping to find in the tech specs.
Attaching shed style roof between existing buildings. Chutzie Building & Construction 4 07-26-2011 04:16 PM
Roof over existing roof Rammertime Roofing/Siding 9 05-25-2011 08:09 AM
torch down or hot mop on flat roof? stanlam Roofing/Siding 14 02-03-2011 11:13 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 09:37 PM
