Flat Rubber Roof. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-14-2011, 12:29 PM   #1
Flat Rubber Roof.
Hello again and thanks for your advice so far:
This EPDM rubber roof I'm doing. A part of it has to lap over bitumastic coated ply. I can't see impact adhesive or water based adhesive working on bitumastic, so what else?
Bitumastic felt lap adhesive perhaps? (which seems very similar to roof and gutter sealant). But isn't bitumastic a bi-product of oil hence will it not eventually dissolve the epdm rubber?
Be glad if you can advise on this. Thanks, Peter.
PedrX is offline   Reply With Quote
Old 08-15-2011, 10:23 AM   #2
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Look into fleeceback EPDM or a coverboard will need to be installed. I have no idea what bitumastic is, sorry.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
The Following User Says Thank You to Grumpy For This Useful Post:
PedrX (08-15-2011)
Old 08-17-2011, 03:11 PM   #3
Grumpy's Anglo American Roofing Consultancy.
Tell you what, Grumpy, a single reply to this thread may not be many but it's one more than I got from a similar forum here in the UK.
I think the word Bitumastic is a combination of Bitumen and Mastic. Bitumen being the black tarry stuff we bung on roads and roofs. In this case it's been used as a paint to protect part of the existing plywood decking to which I'm glueing epdm rubber.
Fleeceback epdm? What on earth is that? A fleecy liner to make it adhere better perhaps?
Old 08-17-2011, 03:46 PM   #4
Grumpy's Avatar
Rewards Points: 552
Yes it's a factory applied fleecy liner. The purpose is not adhesion. Well it does that too. But the purpose is as a seperation between the bitumen.
PedrX (08-17-2011)
Flat roof maintenance retired guy 60 Roofing/Siding 9 09-26-2009 01:44 PM
Flat roof related questions christy123 Roofing/Siding 8 12-09-2008 11:30 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
