Flat Roof Venting Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-13-2007, 02:42 PM   #1
Flat roof venting question
Hi all,
I have a newer rubber roof on a 1915 house. Its a square roof with the joists running the long way from from to back and the roof slopes from front to back (for water runoff).
Right now there are a few small turbine roof vents towards the front of the house.
I plan to raise the ceiling on the 3rd floor to the joists (leaving about 3 inches btwn insulation and roof for venting).
The problem is that these couple vents will now only vent 2 spaces between the joists (there will be no way for air to flow between joists) since I am raising the ceiling to the joists.
My question is this:
Is there some type of line vent for a flat roof? I was thinking a roofer could basically cut a slice the length of the roof (towards the front/higher section) perpendicular to the joists and cap it in some way?
There must be some solution for this.
(heres my wonderful 1 minute depiction)
vendejp is offline   Reply With Quote
Old 09-13-2007, 08:11 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
you can make it yourself or use a clerestory vent to cap the vented area,depending on the roof pitch
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 09-13-2007, 09:03 PM   #3
clerestory Vent? Please help an old roof dog learn a new trick.
I taint near ever seen nothin like dat. Got a link or pic?
tryin to fix stupid here! Thanks for your help
Big Bob is offline   Reply With Quote
Old 09-13-2007, 09:10 PM   #4
http://[URL="http://www.airvent.com/professional/products/ridgeVents-specialtyFilter.shtml"]www.airvent.com/professional/products/ridgeVents-specialtyFilter.shtml[/URL]
Old 09-13-2007, 09:15 PM   #5
there you go big fella!
Old 09-13-2007, 09:31 PM   #6
Thanks, I was having trouble googling "clerestory vent" for information as well. I now know what "net free area" is though. The image you provided is a "peak vent". Im having trouble visualizing how that piece would be applied to a flat roof.
Also, would this type of vent provide enough ventilation?
Old 09-13-2007, 09:47 PM   #7
that`s what" air vent " calls it,the old "lomanco" term is clerestory vent,that`s what you call where the rafter ends at one side,rather than where a ridge beam connects to another,typical of contemporary style homes,the diagram he showed has pitch ,iyou would cut the 3/4" slot same as ridge vent, set elastomer sealant done on the roof where the vent will be secured,set the vent in it,w/a lower pitch I would flatten the gutter style lip before installation so there`s no problems
Old 07-16-2008, 11:26 AM   #8
Success?
How id it go? I need to do something similar and would like to know the results.
-Jay
jayshultis is offline   Reply With Quote
Old 07-17-2008, 03:45 PM   #9
Project got reduced to a point that didnt include removing the ceiling. Sorry.
-Jay
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Roof venting question Douche Roofing/Siding 1 06-29-2006 01:33 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
