-   -   Flat roof venting question (http://www.diychatroom.com/f9/flat-roof-venting-question-11519/)
vendejp 09-13-2007 02:42 PM
Hi all,
I have a newer rubber roof on a 1915 house. Its a square roof with the joists running the long way from from to back and the roof slopes from front to back (for water runoff).
Right now there are a few small turbine roof vents towards the front of the house.
I plan to raise the ceiling on the 3rd floor to the joists (leaving about 3 inches btwn insulation and roof for venting).
The problem is that these couple vents will now only vent 2 spaces between the joists (there will be no way for air to flow between joists) since I am raising the ceiling to the joists.
My question is this:
Is there some type of line vent for a flat roof? I was thinking a roofer could basically cut a slice the length of the roof (towards the front/higher section) perpendicular to the joists and cap it in some way?
There must be some solution for this.
(heres my wonderful 1 minute depiction)
http://brightshift.com/misc/roof_vent.png
the roofing god 09-13-2007 08:11 PM
you can make it yourself or use a clerestory vent to cap the vented area,depending on the roof pitch
Big Bob 09-13-2007 09:03 PM
clerestory Vent? Please help an old roof dog learn a new trick.
I taint near ever seen nothin like dat. Got a link or pic?
tryin to fix stupid here! Thanks for your help
the roofing god 09-13-2007 09:10 PM
http://[URL="http://www.airvent.com/professional/products/ridgeVents-specialtyFilter.shtml"]www.airvent.com/professional/products/ridgeVents-specialtyFilter.shtml[/URL]
the roofing god 09-13-2007 09:15 PM
http://www.airvent.com/professional/...pecialPeak.jpgthere you go big fella!
vendejp 09-13-2007 09:31 PM
Thanks, I was having trouble googling "clerestory vent" for information as well. I now know what "net free area" is though. The image you provided is a "peak vent". Im having trouble visualizing how that piece would be applied to a flat roof.
Also, would this type of vent provide enough ventilation?
the roofing god 09-13-2007 09:47 PM
that`s what" air vent " calls it,the old "lomanco" term is clerestory vent,that`s what you call where the rafter ends at one side,rather than where a ridge beam connects to another,typical of contemporary style homes,the diagram he showed has pitch ,iyou would cut the 3/4" slot same as ridge vent, set elastomer sealant done on the roof where the vent will be secured,set the vent in it,w/a lower pitch I would flatten the gutter style lip before installation so there`s no problems
jayshultis 07-16-2008 11:26 AM
Success?
How id it go? I need to do something similar and would like to know the results.
-Jay
vendejp 07-17-2008 03:45 PM
Project got reduced to a point that didnt include removing the ceiling. Sorry.
-Jay
