Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-12-2009, 12:43 PM   #1
flat roof ventilation
hi can anyone help i'm turning my garage into a bedroom my garage has a flat roof but is also joined to my neighbours what would be the easiest and cheapest way to ventilate the roof without putting a new roof and making sure building control pass the work
twinkle is offline   Reply With Quote
Old 11-12-2009, 04:37 PM   #2
As you called it Building Control, is it in the UK?
stuart45 is offline   Reply With Quote
Old 11-13-2009, 09:34 AM   #3
yes its in uk
Old 11-13-2009, 03:58 PM   #4
It depends on whether the insulation is on top of the deck (warm roof) No ventilation needed, or beneath the deck (cold roof) where 25mm continuous ventilation or equivilent is required.
If you are converting a garage to a bedroom, all of the elements such as walls, roof,floor and windows will have to meet the required U values.
There is some flexibility with trade offs in the elements but you would have to get a SAP rating done with this.
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof headache The Barber Roofing 7 05-17-2008 06:48 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
