Flat Roof Tips - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-29-2011, 01:20 PM   #1
liscenced electrician
Rewards Points: 538
Flat roof tips
Im doing a carport and need some tips on roofing it. I have 1/2 cdx with 1/4" slope per foot and joists are on 16". I was planning to use rolled roofing, but i have a few questions. The only time i have used rolled roofing was for temporary repairs. From what i understand with rolled roofing, First you put down felt paper. Trowel down a thin coat of tar then foll out the rolled roofing, then nail the perimeter. I don't want a bunch of nails poking though on the bottom side, but i figure nailing every 16" is probably not enough? Maybe i should put nailers on the bottom side?
Am i right on how its done?
jimmy21 is offline   Reply With Quote
Old 10-29-2011, 01:28 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
http://www.certainteed.com/products/...e/self-adhered
look into this
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
jimmy21 (10-29-2011)
Old 10-29-2011, 01:47 PM   #3
Rewards Points: 538
Originally Posted by Tom Struble View Post
With something like that, would i put tar paper down first, or would it adhere straight to the cdx?
Old 10-29-2011, 02:42 PM   #4
http://www.certainteed.com/videolibr...=580&width=735
Old 10-30-2011, 11:37 AM   #5
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Tom beat me to the punch. Self adhering modified is pretty much the only DIY roofing system I recommend. EPDM is also another choice. I think the SA mod bit is more forgiving however, which makes it a better DIY system.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 11-02-2011, 11:12 PM   #6
Rewards Points: 538
ended up going with flintastic torch down roofing. Youd have to be a retard to catch the roof on fire. But it took me a bit to feel confident i was doing it right. The first one i put down i don't think i got hot enough and im worried its not adhered good in spots. I would replace that one, but i know i got the edges hot and adhered well, so it would cause a ton of work to get it up. Anything i can do?
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 11:31 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
