Flat Roof With Snow/ice Leaking!!! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-31-2010, 09:42 AM   #1
Flat roof with snow/ice leaking!!!
Wife has buisness with a tar flat roof,water from snow storm is making its way inside of rooms,hallways,kitchen ect. Roof is going to be replaced in spring,WHAT CAN WE DO NOW !! thanks
sugarlimb is offline   Reply With Quote
Old 01-31-2010, 09:56 AM   #2
she is in need of help come on guys!
Old 01-31-2010, 10:48 AM   #3
Most people would put a tarp or other covering over it until Spring
Old 01-31-2010, 10:50 AM   #4
how big is roof
Old 01-31-2010, 11:23 AM   #5
scuba- this is a 90 somthing room building,not incuding the offices,kitchen ect. She has made soft repairs with a company recently. if you mean putting a tarp down now, you still have snow/ice melting under the tarp.
Old 01-31-2010, 11:31 AM   #6
tpolk, Iam not sure, its L-shaped ,think motel with all there sq. ft. of 90 some rooms.i thoght of putting plactic on the inside attached to the ceiling,channelling all the water the center,then catch in containers by small hole in plastic?
Old 01-31-2010, 11:42 AM   #7
Rewards Points: 18
I think you might have to hire a crew and start shovelling.Looking at your weather forecast it's ALL going to be water in a couple of days.Is there a parking lot or pedestrian safe area to drop the snow to?
daveb1 is offline   Reply With Quote
Old 01-31-2010, 11:50 AM   #8
if the leaks are located in certain areas i would have snow removed around roof penetrations and check for flashing problems. Some commercial roofing has its roof drains piped thru the ceilings to outside walls which can leak or become clogged at roof and lead to water build up in other areas. Get snow off first and if you have dropped ceilings you may be able to check underside in wet areas
Old 01-31-2010, 12:17 PM   #9
thanks guys, you dont know how much your iput helps!! the roof does have drainage collectors and we are looking at them now. getting the snow off is #1. my stupid idea of putting up a basket inside of plastic is nothing but a law suit ready to happen. again, thanks 4 ur help!!
Old 01-31-2010, 02:19 PM   #10
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Flat roofing has a bad rap, not bcause a flat roof is bad but because any problems or installation mistakes WILL leak.
If I were the roofer involved in this project I would shovel the snow off the entire area where the leak is occuring. Then depending on the type of roof membrane is there cirrently would determine how I would patch it. Lucas makes a polymer elastomeric that bonds to nearly everything (pvc membranes require a primer first) and will stick to wet surfaces with proper tooling.
Further more check any scuppers, drains or gutters to make sure there is no blockages. After the roof surface has been shoveled inspect each and every seam, pipe, penetration and curb corner. These are the areas a flat roof would first leak in most cases.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 01-31-2010, 05:34 PM   #11
MJW
We had a building like this that leaked in a bad winter. It was actually a Walmart store. We never did the roof, but we were hired to remove the snow and ice. This is what you need to have done. Make sure you get someone qualified, licensed, and insured.
MJW is offline   Reply With Quote
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 05:28 PM
Flat roof venting question vendejp Roofing/Siding 8 07-17-2008 04:45 PM
leaking flat roof weetoo Roofing/Siding 15 04-15-2008 11:58 PM
tar and grvel flat roof leaking alexbadiuk Roofing/Siding 4 01-11-2008 02:29 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
