Flat Roof Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-14-2008, 01:02 PM   #1
Rewards Points: 109
Flat roof replacement
I now have a 35x25 shed dormer roof with about a 3:12 pitch. I has modified bitumen on it. Any suggestions on a replacement that wiil give me a longer life than bitumen?
hitmehhh is offline   Reply With Quote
Old 09-14-2008, 01:26 PM   #2
Doing This Way Too Long
Rewards Points: 532
longer life than bitumen? no, but if it's in need of replacement and you want to diy then I suggest the good SA systems out there. Certainteed flintlastic 3-ply system or GAF liberty are two very good ones for a deck that size.
OldNBroken is offline   Reply With Quote
Old 09-15-2008, 09:09 AM   #3
That is a good material choice for that pitch.
How are the perimeter edges detailed?
How are the seams holding up?
Did they fully torch adhere the membrane down or cheat and only do the seams?
In other words, why does it need replacement?
Ed
Ed the Roofer is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
