Flat Roof Repair--Question On Roofing Type - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-17-2009, 02:21 PM   #1
Flat Roof Repair--Question on roofing type
Hi My son just sent me a couple of pics from D.C. on a 4plex he recently bought that has some leaks in what appears to be a pretty good looking roof--mind you all flat roofs look bad to me.
I am trying to figure out what type of roofing system he has so we can get some reputable roofers out there to patch and perhaps replace two skylights while they are at it.
I assume this is a membrane roofing material that has adhesive attaching it to either decking or plywood (building is circa 1940's) and then has been coated with silver colored coating--aluminum asphalt?
My son says there appear to be 4 leak areas. roof is roughly 34 x 39 and has a parapet separating it from the unit next door.
any wisdom on repairing the leaks and other mainteance recommendations for the rest of the roof would be appreciated. He is preparing to do a major remodel of the building and wants to get it dry and tight.
Any rough estimates on costs for repairs etc. would be helpful.
thanks
jeff
buncoroad is offline   Reply With Quote
Old 10-17-2009, 07:00 PM   #2
Historic Restorer
Filbee's Avatar
It looks like a "Torch Down" roof system, Derby gum, or hot asphalt roof that has been coated with fibered aluminum coating.. Also, there may be multiple layers on it. Closer pics of details and problem areas are needed to properly identify potential issues.
Filbee is offline   Reply With Quote
Old 10-18-2009, 07:35 PM   #3
Licensed Engineer
Rewards Points: 175
Where are the roof drains or wall scuppers?
You need a means to get the water off the roof too!
Vent stack looks too short also.
MI-Roger is offline   Reply With Quote
duro last flat roofing cherylfromcanada Roofing/Siding 4 08-06-2012 11:19 AM
Flat repair roof of condo building Stillwerkin Roofing/Siding 7 03-02-2009 06:34 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
