Flat Roof Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-21-2011, 10:24 PM   #1
Flat roof repair
Hey guys, i recently bought a house that needs some work and i'm trying to learn as I go. There's a flat area off the garage roof that over hangs a walkway that needs repairing. It's worn down to where you can see the base wood in some sections. The flat area of the roof is about 3 foot wide by 15 foot long. I went to homedepot and was told to put down a layer of henry's 201 after cleaning the old roof off, and then put down liberty cap sheet roll shingle (it's self adhesive) on top of the henry's 201. Does that sound right, and if so how long does the henry's have to dry before i put on the cap sheet? I appreciate any help - Brian
Bholt222 is offline   Reply With Quote
Old 07-22-2011, 09:24 AM   #2
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Any advice you get from home cheapo should be taken with a grain of salt. Those guys workign there, for the most part, are absolutely clueless. Occassionally you find an old retured contractor who just wants to stay busy, but mostly young punks who can't get a job anywhere else.
If the roof is worn through in some areas, you have to first fill those areas, or the new roof will have dips and sags in it. I am not familair with 201, is it an ashalt primer? I am not sure why you would need to install that? I think if the roof is as bad as it is, your best bet is to tear off and start over. If you are allowed by code to go over the existing by code, I would fill the spots, mechanically attach a base sheet through the existing, then install the self adhering cap sheet, detail work, etc.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-22-2011, 11:34 AM   #3
AGWhitehouse's Avatar
Totally True!! twice I asked an associate if they carried an item. Once was "laminated beams" to the lumber supervisor. He stared blankly having not a clue what it even was. Then I informed him and he said no. Second was "torque wrench". he promptly said no, so I walk on. not ten feet down the isle was an 8' high, 4' wide display of 2 brands and about 6 sizes and options. I pulled one out and showed it to him. he didn't respond and walked off...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
1'X20' flat roof repair hohadcr Roofing/Siding 2 08-25-2009 11:17 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
