Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-30-2012, 12:29 PM   #1
Flat roof removal and repair.
I have a 10x50 ft flat roof that has major wood rot in about 20% of the total area. There are some standing water areas also. Not exactly sure of the type of existing roofing. Roof deck is T&G. If I decide to remove all of the existing roofing how would one accomplish that. It was heated down I would think and therefore could be difficult to remove. Any suggestions for a DIYer.
johnkurtz3 is offline   Reply With Quote
Old 05-30-2012, 12:44 PM   #2
Doing This Way Too Long
Eww, that's nasty.
Hopefully your roof was done properly and has a nailed base. That is a 40mil sheet nailed to the substrate with simplex. Then the actual roofing is torched/mopped to the base. If so it isn't difficult to take off. Spud shovels and some sharp blades. Just get under the base and start popping it up. If they adhered it to the deck it's usually a real *****.
OldNBroken is offline   Reply With Quote
Old 06-08-2012, 06:44 AM   #3
Concider having the roof redone so it's no longer a flat roof.
It really should have been done that way in the first place.
Old 06-08-2012, 08:33 AM   #4
Exterior Construction
Windows on Wash's Avatar
+1
Sloped ISO always works nicely if you can make it work.
Old 08-23-2012, 12:49 AM   #5
In my opinion you should remove your roof completely and build the new one. This roof is already in a very critical situation and repairing it is not a feasible solution. You can also consult a good roofing company and discuss with it your roof constructor, They will provide you much better solution..
kiarajeckson is offline   Reply With Quote
Drywall repair after wall removal kman1455 Drywall & Plaster 3 02-21-2012 08:01 PM
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 11:21 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing 15 10-09-2011 10:25 AM
New roof installed, but damaged wood not replaced? grimaila Roofing 4 08-31-2010 03:39 PM
How do I repair my ceiling after removal of downlighters? RUTH CORRIGAN Carpentry 3 04-01-2008 08:02 AM
