Flat Roof, Not So Flat! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-18-2010, 02:35 AM   #1
Flat roof, not so flat!
Hello - I have a flat roof question. My flat roof is beginning to pool water after a rain. It evaporates within 48 hours but it bothers the crap out of me. It looks like the surface is white, or maybe black but painted white. Looks petroleum based. Anyhow, is there such thing as a self leveling type of roofing compound that I could put up there to fill in the depressions?
I was also thinking about throwing some more sealant up there, because what is up there has lots of cracks in it. Any suggestions? I was at the Lowe's tonight and they had several to choose from.
Thanks so much,
Jay
vgoose is offline   Reply With Quote
Old 06-18-2010, 07:17 AM   #2
Residential Roofer
Slyfox's Avatar
A picture or two would be very helpful.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 06-18-2010, 11:59 AM   #3
pics!
Sure thing Mr. Slyfox. Here are some pictures of the roof in question. Again, i am wondering if there is anything I can put in depressions to stop the pooling, and what I should use to seal it all up nice and tight.
Thanks so much,
Jay
Picture #1
Picture #2
Picture #3
Picture #4
Old 06-18-2010, 05:56 PM   #4
Are the links to these pics working okay? Any help would be greatly appreciated. Thanks!
Jay
Old 06-18-2010, 08:39 PM   #5
Residential Roofer
Slyfox's Avatar
Yes the links are working, sorry for the delay in responding but I had family business to take care of after work.
You could re-coat the roof to seal in the cracks and simply blob 'build up' the coating in the ponding areas, it's not a fix but it could/will help some.
The ponding issue should be noted and kept in mind for when you do end up re-roofing you can make sure your roofer addresses that issue than.
As far as what type of coating, I would find your local roofing supply store,
like ABC Supply or a local lumber yard, they will be of more assistance than the minimum wage guys/gals at lowes.
Take your pictures with you and they can assist you on what would be the best coating for your area.
Facebook <> Twitter
Old 07-06-2010, 10:25 AM   #6
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
If the water is evaporating within 48 hours you are completely within acceptable limits and warranty requirements. Messing it may just be a waste of time, and you know what they say about sleeping dogs.
However if you do choose to do something about it, there are some self leveling compounds. I think Henry may make one. I have no experience with these products however. I have heard some old school hot tar roofers using actual self leveling concrete and then glazing with tar, although I would personally be concerned with the added weight.
Typically when it comes to puddles we tear the low spot and build up with extra insulation. This will not completely defeat the puddle and sometimes just moves it, what we call "chasing the puddle". There are no two ways around it, flat roofs almost always have some degree of standing water. It's a normal natural occurence that in most cases is not a problem.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 05:28 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 07:41 PM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
