Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-07-2010, 06:56 PM   #16
Flat roof, need help
Originally Posted by KyleB View Post
You were quoted 4 to 5 thousand for a 11'x13' flat roof with no protrusions?!?!?!?!?!!? That's bloody robbery.
What ever roofing companies quoted that to you, never call them for anything.
?? What's a good price that I should expect then?
salahnajm is offline   Reply With Quote
Old 04-07-2010, 08:58 PM   #17
11' x 13', correct? That's a little over one square. What type of membrane were they proposing for you? Since we've been talking so much about EPDM, I will tell you that any roofing company that does a fair amount of EPDM could do that roof with the scrap material left over from a bigger job. $1K maybe? 4 to 5 is totally out in left field.
KyleB is offline   Reply With Quote
Old 04-08-2010, 12:04 AM   #18
Commercial Roofing
AaronB's Avatar
Get a picture of the whole roof and show us where the leak is showing up in the house.
Kyle, I have done some one square roofs with so much detail work they took two good roofers two days to do. Can't tell without pics.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-08-2010, 10:35 AM   #19
You should hear the quotes I am getting in NYC to do my roof.
I initially though about not bothering with it myself, especially since I will have to do it and pull a few guys from a remodel I am doing. The cheapest quote I got was $11k for 1200sq ft. remove replace, and they were agreing to everything I suggested. Basically noobs.
Company I liked, 19k.
Yup, doing it myself.
slickgt1 is offline   Reply With Quote
Old 04-09-2010, 07:27 PM   #20
Here are the pictures of my roof... I honestly feel its a small roof and can do it myself (with some extra work and time).
I don't want to pay anymore 'roofers' unless it still leaks and then I will hire a professional company and pay extra money. What really bothers me with these 'independent' or 'cheap' roofers is that they do the work and DO NOT GUARANTEE their work. I honestly called them back and told them that I DO NOT want them to come back to fix the roof, I just want to ask them the questions I'm asking you guys... one of them said he'll come by in a few days (that was like 3 weeks ago).
When we got these 2 roofers, we went through 5-6 others and all of them said that our roof doesnt need to be ripped (they quoted around 4-5k if we decided to rip and install a whole new roof, I think one said like 2-3K).
My experience sucks and I do not want to deal with similar people anymore. I'm willing to hire a professional company, after I do it myself and find its not working..
I just need to figure out which material would be best to cover the roof with a single ply material.
Flat roof, need help-img_0662.jpg   Flat roof, need help-img_0663.jpg   Flat roof, need help-img_0664.jpg   Flat roof, need help-img_0666.jpg
Old 04-10-2010, 01:11 PM   #21
Commercial Roofing
AaronB's Avatar
To do this right, you're going to have to remove some siding, and the door from its jamb and replace all of it.
Old 04-10-2010, 02:59 PM   #22
Same here, although for $4000 on a one square EPDM roof I would expect a TON of detail work.
Old 04-10-2010, 03:55 PM   #23
Commercial Roofing
AaronB's Avatar
Where is the water showing up inside?
Old 04-10-2010, 05:28 PM   #24
You may consider putting rubber down, as it solved my flat roof problem. It comes 10 feet wide and any length and its as thick as a car innertube. Tear up all the old,replace any rotten wood .You may get some wrinkles, but so what .......just caulk the seams and use galvanized roofing nails. Your size roof for less than 200 bucks for parts. And no liquid tar please.
And get rid of that railing........keep a ladder up there if you need it in case of fire.
bernieb is offline   Reply With Quote
Old 04-10-2010, 07:52 PM   #25
Commercial Roofing
AaronB's Avatar
This is by far the most incorrect way I have ever read on how to install a rubber roof.
Old 04-11-2010, 08:10 AM   #26
I respect your title as being a professional, so please inform me ,have you had any rubber roofs blow up and away with your method, so to speak?
Old 04-12-2010, 12:16 PM   #27
I'm trying to find a solution WITHOUT having to rip out my old roof or cutting any edges off... I want to cover it. Its a minor leak, only with heavy rain. If I start ripping the roof I know I'm going to dig myself into a very deep hole
I know I can't put down EPDM over my torch down. Can I use a membrane like this to cover my roof and then put the EPDM over it??
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
BTW I'm not sure where the water is dripping from as the inside has a finished ceiling (again I do not want to rip it out to see were water is coming from)
Old 04-12-2010, 01:51 PM   #28
Residential Roofer
Slyfox's Avatar
Any material with an asphalt/oil base will cause issues if it comes in contact with the EPDM.
You can cover the field with insulation 'Fiber board or ISO' fastened into the existing roof 'not loose laid' and glue your EPDM to it.
You will still have detail work to deal with at the edges of the roof, walls, etc.
If it's a minor leak, how about you use Roof Cement & Cotton Membrane 'mesh' to cover all seams, flashing's and any blisters or rotting portions of the existing roof and than coat it with a fiber based aluminum coating.
This method will add years of life to your roof, will not cost much more and is far easier a method for a diy project.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 04-12-2010, 02:52 PM   #29
Commercial Roofing
AaronB's Avatar
My question was... Where is the lak showing up in the house, not where is it entering the roofing.
If you can answer this question, we may be able to provide some direction on where to look.
Old 04-12-2010, 06:44 PM   #30
The ceiling as you can see from the pics is finished. I do not want to rip it out to see where the leak is coming from. The circles (poorly drawn) are where I see water drops with heavy rain. The arrow is where the door to access the roof from above is (you see the door on my previous pictures of the roof)
Flat roof, need help-photo-2-2-.jpg   Flat roof, need help-photo-3-2-.jpg   Flat roof, need help-photo.jpg
Tags
epdm, flat roof, gutters, leaking, pvc
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 05:28 PM
Blown Insulation - Flat roof AndrewF Roofing 1 12-31-2009 07:41 PM
Flat roof related questions christy123 Roofing 8 12-10-2008 12:30 AM
Flat roof headache The Barber Roofing 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
