Flat Roof (my Porch) Is Leaking In The Corner - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-08-2013, 10:48 AM   #1
Rewards Points: 119
Flat Roof (my porch) is leaking in the corner
It would appear that the water runs down the slope of the shingle roof and is irritating the corner of the flat roof which is over my porch. You can see where the white gravel of the flat roof has worn away in the corner. Can someone please advise me on the best way to go about fixing this leak? Is there some kind of miniature gutter system that I can install to catch water as it rolls off the shingle roof and direct it away from the flat roof? Thank You.
SpaceCoast is offline   Reply With Quote
Old 04-08-2013, 12:00 PM   #2
Doing This Way Too Long
Rewards Points: 532
Just 3-course it...along with that vertical lap next to it.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
1985gt (04-08-2013)
Old 04-18-2013, 11:03 AM   #3
Rewards Points: 119
What do you recommend 3 coursing it with? Henry 209 and fabric?
Old 04-18-2013, 12:23 PM   #4
Rewards Points: 532
That would work. You are going to get more life out of the modifieds like 209 than the cheaper asphalts.
When done, either embedding granules into it or aluminum coating will help to get a little more life out of it. The sun is asphalts worst enemy. Well, that and crappy roofers.
Oh, and use cotton fabric if you can, not fiberglass. Fiberglass is fine on long, flat stretches but does not conform as easily as cotton for your situation.
Old 04-22-2013, 04:41 AM   #5
Rewards Points: 119
I don't see granules on Home Depot or Lowes websites. Any tips? Thanks.
Old 04-22-2013, 09:08 AM   #6
Roofmaster
Rewards Points: 2,210
Look at the valley above. It looks like it is closed cut, then it transitions to a weave that is bucking water. The low slope roof is bridged at the angle change, there is no cant strip, and there is no separate flashing countering the field sheet, you therefore have one ply of bridged membrane where you should have two plies nested.
You should get a real roofer in to correct the valley and the low slope roof, or read up and do it yourself. Dope and fabric might work in the meantime, but your leak may be coming from the valley above.
Try water testing with a hose from the bottom up.
Old 04-22-2013, 09:27 AM   #7
Rewards Points: 532
No they won't. Either sweep some up if you can or just buy a gallon of non-fibered aluminum coat and coat all non-granulated areas.
Leaking Flat Roof Balcony briantroy Roofing/Siding 5 12-08-2010 10:47 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
How to combine two different angles of a porch roof at the corner northstarws Building & Construction 6 08-10-2008 10:36 AM
leaking flat roof weetoo Roofing/Siding 15 04-15-2008 10:58 PM
tar and grvel flat roof leaking alexbadiuk Roofing/Siding 4 01-11-2008 01:29 PM
