Flat Roof Leaks - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-26-2012, 11:24 AM   #1
Flat roof leaks
the flat roof leaks at the joint to where it meets the dormer wall
Rick Turner is offline   Reply With Quote
Old 10-26-2012, 01:30 PM   #2
funfool's Avatar
Rewards Points: 534
Hello Rick, welcome to the forums.
I have to admit your post leaves a lot for imagination
There are many here that could offer advice, but need more info.
What is current roofing material now? Does it have tar and gravel on it?
Many different ways to tackle this problem.
funfool is offline   Reply With Quote
Old 10-26-2012, 02:20 PM   #3
Rewards Points: 12,856
And a picture would sure help.
Old 10-26-2012, 02:46 PM   #4
Gymschu's Avatar
Rewards Points: 230
..........and, all flat roofs leak........eventually.
The Following User Says Thank You to Gymschu For This Useful Post:
joecaption (10-26-2012)
Old 10-26-2012, 06:04 PM   #5
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
All roofs leak eventually. The only difference between a good roofer and abad one is how long it takes to look.
All roofs need routine maintenance. The difference between a flat and sloped roof is gravity.
A flat roof requires professional installation, or at least a very very very great attention to detail for a DIYer.
You can make a minor mistake on a flat roof and it will leak. You can make a minor mistake on a sloped roof and it might not leak for awhile or might only leak on occasion.
The point I am trying to make is it's not the flat roof's fault that it leaks, it almost always installation error.
What type of roof and what type of wall material? How many layers of roofing material on the roof?
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
commercial building, flat roof leaks noquacks Roofing/Siding 14 10-06-2010 04:26 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Flat Roof Leaks sinjin6 Roofing/Siding 4 05-20-2009 12:15 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
