Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-06-2006, 02:59 PM   #1
Question
Flat roof leaking
Another thread relating to my recent house purchase .
I have a house with an extension where the roof is flat (10% gratient), today heavy ran and we get a leak . The leak is at the end of the roof so could have started from many places.
Does anyone have any hints or tips as to how to trace the source of the leak.
Does anyone have any ideas as to a temporary fix to get through an English winter. The idea was that next year (subject to saving the cash) that we would pitch the roof properly.
tractorboy is offline   Reply With Quote
Old 10-06-2006, 05:47 PM   #2
Commercial Roofing
AaronB's Avatar
Flat roof leaking
Well, what kind of roofing is on it now? Can you post any pics?
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-06-2006, 09:09 PM   #3
Flat roof leaking
What is the size of the roof?
Can you put up a temporary tarp until you are able to replace?
redline is offline   Reply With Quote
Old 10-07-2006, 07:38 AM   #4
Flat roof leaking
low slope roofs can be a pain. if you are going to re-pitch within a year i have a suggeston. i have incountered this problem recently with a commercial building. we applied rolled roofing but insted of overlapping the standard 2", we overlapped 4" and sealed all seams and nails with Fibered wet/dry roof sealer. start at the bottom (of-course) and when you get to the top make sure that the roofing is tucked under the siding atleast a little. hope that helps.
Randy
hvacdude is offline   Reply With Quote
Old 10-07-2006, 09:19 AM   #5
Commercial Roofing
AaronB's Avatar
Flat roof leaking
Randy
Did you nail through both layers at the laps?
Flat rrofs are really not a pain....HVAC, now thats a pain.
Old 10-10-2006, 05:12 PM   #6
Question
Flat roof leaking
The roof is plastic with seams (plastic connections) run down the slope. They all look ok. My concern is most problem the screws used to hold the roof down.
Is there any dangers is climbing on the roof, with a board?
Old 10-10-2006, 07:22 PM   #7
World famous jerk.
Flat roof leaking
Eeeee... corrugated plastic roofing? I wouldn't go marching around on that if you can help it. Maybe a big blue tarp will get you through the winter if money is tight.
mdshunk is offline   Reply With Quote
Old 10-10-2006, 08:22 PM   #8
Flat roof leaking
Are rubber gaskets between the screws and the roof material?
Depends on the spacing between the rafters, the weight of the person climbing on the roof, the shape of the roof, the age of the roof...
If you are able to stay above the rafters then you may be a little safer but hard to tell without a photo?
Leaking Cement Flat Roof surritab Roofing 1 01-31-2007 12:48 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 12:03 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
