Flat roof leaking
Another thread relating to my recent house purchase:mad: .
I have a house with an extension where the roof is flat (10% gratient), today heavy ran and we get a leak:furious: . The leak is at the end of the roof so could have started from many places. Does anyone have any hints or tips as to how to trace the source of the leak. Does anyone have any ideas as to a temporary fix to get through an English winter. The idea was that next year (subject to saving the cash) that we would pitch the roof properly. |
Well, what kind of roofing is on it now? Can you post any pics?
Can you put up a temporary tarp until you are able to replace? |
low slope roofs can be a pain. if you are going to re-pitch within a year i have a suggeston. i have incountered this problem recently with a commercial building. we applied rolled roofing but insted of overlapping the standard 2", we overlapped 4" and sealed all seams and nails with Fibered wet/dry roof sealer. start at the bottom (of-course) and when you get to the top make sure that the roofing is tucked under the siding atleast a little. hope that helps.
Randy |
Flat rrofs are really not a pain....HVAC, now thats a pain. :) |
The roof is plastic with seams (plastic connections) run down the slope. They all look ok. My concern is most problem the screws used to hold the roof down. Is there any dangers is climbing on the roof, with a board? |
Eeeee... corrugated plastic roofing? I wouldn't go marching around on that if you can help it. Maybe a big blue tarp will get you through the winter if money is tight.
If you are able to stay above the rafters then you may be a little safer but hard to tell without a photo? |
| All times are GMT -4. The time now is 01:13 AM. |
