Flat Roof Leak (used as patio above living area)
strip the slate or tile,remove the old roof,install a new flat roof,run extra strips roofing as cushions for sleepers every 12-16"build a platform from pressure treated lumber,lay the slate(I assume this is rectangular blue slate,1" thick or the like)without grout so any water runs thru to the lower roof and exits
"If it`s worth doing,It`s worth doing right!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
