Flat Roof Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-26-2006, 01:38 PM   #16
Commercial Roofing
AaronB's Avatar
The fibrated has organic fibers in it to reduce crackling, but find it better to use non fibrated over smooth surfaced roofs.
Coal tar has such a low melting point that it will flow into and seal smaller holes and/or alligatoring that may occur as the surface of the roof slowly dries out. This flow characteristic is why you would see some old roofing construction with drains that sit above the roof an inch or so. They used to do this to intentionally pond water to keep the pitch cool, so I read. I have never installed coal tar, but have torn off literally tons of it.
Are you planning in coating your coal tar roof? If so, why?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-26-2006, 05:25 PM   #17
thanks again. Try to touch up the old coating to make it shine :-)
stone is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
