Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-10-2005, 02:09 PM   #1
Angry
flat roof leak
My house was built in 1900. The roof is tin, has been maintained and is in relatively good condition. Over the past 100+ years the house has been added on to 4 times, one of which, includes the enclosure of the back porch, When this occurred it created 3 different roof "pitches" all converging on to the roof of the enclosed porch --which is flat. It leakes (profusely) when it rains. This has been ongoing for several years. I have had it "fixed" several times. The tin roof has been coated with that thick silver roof stuff. It has even had an additional angled roof, with a slight pitch built above it. My roof behaves as though nothing has been done to it. The problem has now gone on for so long that the 2-foot square area (where the water comes in) of slat board ceiling is completed rotted, I had to tear it out. Now I can see the tin roof, from the INSIDE!!
I have been on top of the roof and in my attic. I cannot , nor can anyone else tell me at what point the water is incoming! How can this be? I am to the point of hysteria with this. I feel as though I need a roof exorcist! Can anyone advise? Someone mentioned to me that there is a proceedure called infared imaging that can detect where moisture is? I live in eastern North Carolina. Please help.
snikda9 is offline   Reply With Quote
Old 12-10-2005, 03:33 PM   #2
Commercial Roofing
AaronB's Avatar
flat roof leak
If you can post a few pictures from different angles I think I could help.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 12-12-2005, 07:48 AM   #3
flat roof leak
i recently sold a house with a flat roof and i will NEVER own another with a flat roof. it just doesnt seem right for a roof to be flat. i had several roof problems, one year it would be fixed then the next year trouble would brew again. several patching jobs by myself or contractor, complete tear offs and fixes. we finally put on a rubber roof and leaks continued were the rubber met the shingled roof. my only advice to you is this; look up and work with only flat roof "expert" contractors. not every roofer has years of expierience in flat roof repair.
THEBIGPUNN is offline   Reply With Quote
Old 12-12-2005, 10:24 AM   #4
Commercial Roofing
AaronB's Avatar
flat roof leak
That is correct, BIGPUNN. Low slope roofing is a whole other ballgame. I have many flat roofs currently under warranty, and no leak calls, even with the 12" of melting snow we have from last week.
You definitely want to use a low slope expert for the low slopers.
Old 12-27-2005, 01:02 PM   #5
flat roof leak
Aaron, thank you so much for responding I will try to do this very soon. Jacky from N.C.
Old 12-27-2005, 01:04 PM   #6
flat roof leak
Thank you Aaron for reponding I will try and post pictures soon. Jacky in NC
Old 12-27-2005, 01:06 PM   #7
flat roof leak
Thanks Aaron, I will do this soon. Jacky in NC
Old 01-06-2006, 09:34 PM   #8
flat roof leak
I am in escrow on a house with a low pitch roof. It has composite shingles. all the skylights are leaking. One roofer said it can only be redone in tar and gravel, which totally changes the look of the house. Is there any alternative to tar and gravel for a low pitch roof? Something more classic looking?
CarlaC is offline   Reply With Quote
Old 01-06-2006, 09:43 PM   #9
Commercial Roofing
AaronB's Avatar
flat roof leak
Yes, you could consdier...
BUR (tar and gravel)
Modified bitumen (or a combination of BUR and modbit)
EPDM
Thermoplastics (PVC TPO, etc)
SPF (spray polyurethane foam)
For a classic shingle look, http://www.cooleygroup.com/webcont.nsf/0/bldindex
The cooley thermoplastic Illusions is meant for your situation. Now find a reputable, properly insured contractor in your area that does thermosets.
Hope this helps.
Old 01-06-2006, 11:09 PM   #10
Contractor
flat roof leak
Flat roofs should not leak. We have many here on 'Spanish Mission' homes and on 'Florida rooms'. We can also have a mess of rain driven by winds of over 100 MPH. Listen to the experts. Aaron is one. Grumpy may join in too.
Teetorbilt is offline   Reply With Quote
Old 01-23-2006, 02:23 PM   #11
flat roof leak
Does anyone knows the name of that silver roof stuff? Thanks.
stone is offline   Reply With Quote
Old 01-23-2006, 02:35 PM   #12
Commercial Roofing
AaronB's Avatar
flat roof leak
There are many different silver roof stuffs. What product/purpose?
Old 01-25-2006, 09:21 PM   #13
flat roof leak
Aaron,
It is something like the attachement. It is aluminum paint? Or can one use aluminum paint on it -- I heard that some aluminum paint could not be used on coal tar or dead level roof, do you know why?
Old 01-26-2006, 07:08 AM   #14
Commercial Roofing
AaronB's Avatar
flat roof leak
Looks like non-fibrated aluminum roof caoing.
Coal tar will eat the aluminum paint up, and dead level roofs pond water, deteriorating the aluminum coating.
Usually coal tar on a dead level roof. Why would you want to coat a coal tar BUR? It is a self-sealing roof designed to flow with the heat of the sun.
Old 01-26-2006, 01:29 PM   #15
flat roof leak
Thanks Aaron.
What is the difference between non-fibrated and fibrated aluminum coating? And what do you mean "flow with the heat of the sun"?
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Reflective Coating on Flat Roof MelindaA Roofing 3 01-05-2006 06:08 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
