Flat Roof Help?! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-29-2007, 01:12 PM   #1
one determined mama
flat roof help?!
Hi,
First time poster here. I have a bit or a problem. I live in a 57 year old home that was recently sprung a leak like Niagara falls. The roof in question is a flat tar and gravel roof over a sun porch. It was supposedly "patched" 3 years ago....before I owned the house (we purchased it from my husband's grandmother). I assume they outright too advantage of her and completely half-a$$ed the repair (especially since another "patch" of their's is leaking too-just not as bad)...now since we just took owner ship of this house (the leak occurred the next day-literally-we awoke to find a soggy sun room with a nice waterfall in the middle) and would like to get it insured, we have been told the roof must be repaired before we can think of getting insurance. Now what I'm trying to figure out is what I should replace it (we're just re-roofing/the drywall damage repair inside will be DIY) with and how much of bite it's going to take out of my very small income (a very rough ball park-it's roughly 200 sq ft) ? I really would love do this myself, but it appears that's out of the question from the other flat roof posts I've seen...also, if it makes a difference, we live in central GA, so things like snow aren't really an issue, but the heat produced is....so, best advice?
mudpaw is offline   Reply With Quote
Old 11-29-2007, 06:05 PM   #2
It could cost anwhere between $ 400.00 to $ 2,000.00 depending on what needs to be done.
If there is decking damage, then the old T & G roof must come off.
Is it primed down to the existing wood surface? No one can say without coring it. Taking a core sample.
How many times has it been reroofed over and how many times has it been patched.
If the other company only did a "Patch" job, then 3 years is actually pretty decent. I assume it was leaking prior to them doing the "Patch" job too, so they stopped the leak for 3 years, it would seem.
What kind of siding does the roof tie into?
An on the roof evaluation by a local contractor will at least get you some ideas.
Ed
Ed the Roofer is offline   Reply With Quote
Old 12-01-2007, 11:44 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
remove the old roofing,install some iso cyanurate insulation,and look into polyglasses,modified bitumen torch down system(polykool ?),it`s white to reflect the heat off of the material,or you may have an IB installer in the area,Their white membranes are also very good at reflecting the heat,and it`s possible to get a "lifetime" residential warranty
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
