Flat Roof Help - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-09-2012, 03:44 PM   #1
flat roof help
Hi I have a flat roof that is for a back porch. it not a complete flat roof has a small slope to it. i know i need to replace some wood and some type of roofing. I have 600.00 to do the work it is just under 400sq ft. any tips or ideas on what i could use. could i just use shingles or is it better to go with a roll roofing system or a paneling type system.
timw725 is offline   Reply With Quote
Old 03-09-2012, 05:14 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
You can't put shingles on a flat roof.
titanoman is offline   Reply With Quote
Old 03-09-2012, 06:02 PM   #3
Framing Contractor
Rewards Points: 112
For that size with hardly any slope, I would probably recommend a rubber roof. It goes down with a rubber cement, and if you do your research you can probably handle it. We are building a new house now that has several areas of roof that are almost flat. They will all get epdm rubber and have floating decks installed over that.
sixeightten is offline   Reply With Quote
Old 03-09-2012, 10:33 PM   #4
Doing This Way Too Long
Rewards Points: 532
Yep, for that tight a budget look at a 60mil epdm. A little research and planning and it is fairly DIY friendly.
OldNBroken is offline   Reply With Quote
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 05:28 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 07:41 PM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
