Flat Roof Drains - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-08-2011, 03:25 PM   #1
Rewards Points: 252
Flat roof drains
Can a flat roof drain be replaced from the rooftop only (no access from underneath)? Is there a way other than using a retrofit drain?
I'm not very knowledgable when it comes to drains, so any info on you could share about a typical installation would be great!
shazapple is offline   Reply With Quote
Old 08-08-2011, 11:30 PM   #2
Yes they sell drains that have expandable seals that you place in the drain pipe and tighten some bolt that expands the bottom. Around here they are about $175.00.
Omegaroofer is offline   Reply With Quote
Old 08-10-2011, 10:58 AM   #3
Grumpy's Avatar
Rewards Points: 508
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Omega, that's the retrofit drain he was referring to in his thread. i think he is lookign for an alternative to a retrofit for some reason.
Is the pipe broken or why do you NOT want a retrofit? There is always access from beneath, just requires a new ceiling and/or wall.
FWIW, I stay away from the drains inserts that have the expanding foam seal. I prefer the manual seals like on the Olympic Uflow drains. They cost more money but are removeable.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-10-2011, 12:26 PM   #4
Rewards Points: 252
Pipe is not broken, but it is standard procedure to replace the existing drain (unless it has been cast in place in a concrete deck). Our local warranty program also prefers retrofit drains be the last resort, so I'm just trying to figure out the reasoning behind it.
I've heard of the u-flow type drains, which seem to be the best retrofit method. Wouldn't these make the pipe size smaller? Do you have to clean or smooth the surface of the pipe where the seal goes?
Have you ever dealt with expandable drain bowls?
Old 08-12-2011, 10:44 PM   #5
Grumpy's Avatar
Rewards Points: 508
You don't "replace" the drain do you? I mean whos' standard procedure is it to "replace" a drain? Insert sure, I can see a drain insert as a standard, but "replacing" a drain is a lot of work if it aint broke.
yes the pipe will shrink abotu 1/2" at the opening with a U flow. It hasn't been a problem yet for us. I'm less concerned with the restriction of 1/2" than I am with a imporoperly flashed drain bowl.
Most of the time in my proposal we bid to reuse the drain hardware. If the drain hardware can't be reused, as determined at the time of tear off, then I give a line item upcharge in the proposal for Uflow or Marathon universal drain rings and hardware. Universal drain rings work great when the bowl is in good condition and needs no insert. A new clamping ring and bee hive and you're done. No restriction of water flow. However even though they are called universal, there is no such thing as one size fits all; hence the U flow enters into the equation.
Can you provide a link for the expandalbe drain bowls? I have never heard of them.
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 07:41 PM
Flat roof related questions christy123 Roofing/Siding 8 12-10-2008 12:30 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 06:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
